engine stumbling/running rough while cruising
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mattbatson, Sep 19, 2020.
  1. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    Yes
    I can try that as well
    Thanks
  2. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    It could also be that it started running rough as the software update was over due... then continued running rough for a day after as the computer had to learn the update ?
  3. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    update...she drove 15 hour round trip to see her mom
    no issues...runs great with no engine shake.
    I think it was the software update...believe it or not.
    If others on here have the shakes, they should check to make sure there are no outstanding software updates.
    I've not done a leak down or looked at the car any further due to it seemingly being fixed.
    this was just an update for FYI purposes...and thanks for all the responses.
    going to try to get her car to 300 k miles ;)
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    What was this specific update? Inverter? It should be on the paperwork.
  5. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    I was out of town while this is was being done at the dealer ... girlfriends car
    I’ll see if my girlfriend still has the receipt
  6. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Not to be a wet blanket, but the engine/hybrid ECUS are not intelligent enough to cause a misfire issue because they are due for an update. I suspect poor quality fuel, an impending coil failure, or the previously mentioned head gasket leak. The nature of how the ICE operates, it only takes droplets of coolant to trigger a misfire. In the early stages of failure of the head gasket, droplets disappearing from the system would not show up for some time. It would certainly show up on a 15 hour round trip though. The leak down test is the most likely way to check for that. The other way, pressurize the cooling system with the rental tool that most parts houses have, while peeking in the cylinder with the rental borescope.
    fotomoto likes this.
