Engine swap question
Discussion in 'Gen 3 Prius Technical Discussion' started by cnc97, Jun 29, 2018.
  1. Rmay635703
    Rmay635703 Senior Member
    2,699
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    Good Work
    Maybe the Gen IV swap will be worth the pain to the elite few because of the fuel economy?
  2. putty
    putty Member
    147
    39
    somewhere in the swamps of Jersey
    hopefully a Nutzaboutbolts' video will be coming out on this
    Threej likes this.
  3. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I am thru the first full tank of gas post engine swap. The question of did I fix it can be considered answered “Yes”. 621.3 miles on 11.8 gallon of gas.
    RMB, m.wynn, Mendel Leisk and 2 others like this.
  4. ASRDogman
    ASRDogman Senior Member
    8,063
    4,086
    I'm very happy for you!
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I just like how gen 4's ICE comes on after 54 mph, turd gen will only go up to 43 mph then ICE kicks in. Maybe hire someone to swap the engine for me, gen 4 looks aesthetically awful but I'd take the engine over gen 3 engine any day.
    m.wynn and Aaron Vitolins like this.
  6. ChapmanF
    19,016
    That likely has more to do with differences in the transaxle than in the engine. So for the next challenge project, retrofitting a Gen 4 tranny to a Gen 3? Should leave lots of extra room for air horns or something (an aux battery perhaps?) at the left side of the engine compartment....
    -Chap
  7. Ragingfit
    Ragingfit Active Member
    189
    249
    Aurora, IL
    You've answered a lot of my questions about the Gen 4 engine swap into a Gen 3. Here's the result of my swap into a 2012 Prius v. I was able to use the head after modifying a few things. 20180726_112238.jpg 20180727_153048 (1).jpg 20180724_122643.jpg
    iplug, qettyz, m.wynn and 7 others like this.
  8. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Looks like you got the Gen 4 EGR cooler with yours. I could have used the Gen 4 head if I would have had that I think. I had all of the metal pipes for the coolant hoses.
  9. Mendel Leisk
    42,341
    @Ragingfit : Using Gen 4 EGR cooler you likely have a misfit connecting to the (Gen 3) exhaust. Hopefully a gap, not interference, and then it's a matter of fab'ing an adapter to bridge the gap? Or was there no misfit?? That would be interesting...
  10. Rmay635703
    2,699
    1,729
    2013 Chevy Volt
    A V might be a bit different than a normal Gen III
  11. Ragingfit
    189
    249
    Aurora, IL
    I used the gen 3 intake, EGR and EGR cooler. Had to cut a nub off the head that interfered with a gen 3 EGR cooler pipe. 20180727_135143.jpg
    m.wynn, Raytheeagle, putty and 2 others like this.
  12. Ragingfit
    189
    249
    Aurora, IL
    A v's engine bay is a Prius engine bay - same everything until the cat and exhaust pipe.
    RightOnTime and Mendel Leisk like this.
  13. Mendel Leisk
    42,341
    Does the EGR cooler, valve and pipe then free-span between intake manifold and exhaust connection? Or are some of the boltings in-between compatible? I think even free-spanning it would be stiff as heck, but just curious.
    Good info btw.
  14. Ragingfit
    189
    249
    Aurora, IL
    Yes, the EGR cooler is not connected to the block or the head. It is VERY stiff and does not move. You may be able to get the dreaded bottom bolt / stud & nut into the head but I don't want to. Also, I had to use the Gen 3 exhaust manifold because I did not have a gen 4. I'm getting a gen 4 exhaust manifold today to test out the possibility of using the gen 4 intake manifold, EGR and EGR cooler on my car. I suspect there will be a misalignment at the cat. We'll see. Stay tuned!
  15. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I had very little issue with that bottom nut. Deep socket plus 1” extension did the trick. I did have a small magnet inside my deep socket though.
  16. Ragingfit
    189
    249
    Aurora, IL
    It's not a straight forward swap. There are 5 or 6 modifications you have to make. This is what I did; I used the gen 4 engine, head, water pump, thermostat, fuel rail, injectors, coils, spark plugs, valve cover & sensors. I did not dismantle the engine in any way. I wanted to use all the new stuff that came with my salvage engine because it had 3200 miles on it. I could NOT use the Gen 4 intake manifold, EGR or EGR cooler, and I did not have a Gen 4 exhaust manifold. I will try all the gen 4 stuff, but the point that things don't line up just moves down the line. You must change the flywheel / damper, thank you cnc97 for that one. You must lengthen the wires going to the temp sensor on the head because it moves forward. You must remove the "S" shaped lower (driver's side) radiator pipe and replace it with a 1" galvanized pipe, 8" long or use a Gen 4 lower radiator hose. You must cut a 3/4" to 1" nub off where the EGR cooler mounts to the new head to make room for the OLD EGR cooler. The EGR cooler is held only buy the exhaust manifold and the intake manifold. It is SOLID! You must relocate the ground terminals to the engine. I had to drill out the terminal holes and bolt them to the front. Finally, you must install a 1/2" PEX T in one of the coolant lines because you loose a hose connection when you remove the "S" shaped pipe. I`made the T between the coolant tank, head and throttle body. I will be doing another GEN 4 swap, into a 2012 Toyota Prius v at the end of August and hope to video the entire process. Stay tuned, and tell your friends. Thanks for your interest. Sincerely, Thomas E. Bourassa - Fix That Prius!
    sega64, m.wynn, RightOnTime and 9 others like this.
  17. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Sounds like you have this under control. I look forward to seeing the next one unfold.
    Raytheeagle, padroo and mjoo like this.
  18. Ragingfit
    189
    249
    Aurora, IL
    You, cnc97, inspired me to do the swap. You did all the research. You answered all the questions. I knew it was going to work because you went there first. Thanks for leading the way.
    sega64, amos, RMB and 4 others like this.
  19. padroo
    padroo Senior Member
    2,763
    2,253
    Looks like the engine swap from high mileage Gen 3 with Gen 4 motors is going to be a common thing now thanks to our new pioneers.:cool:
    RMB likes this.
  20. JC91006
    16,936
    8,647
    Hopefully not too common. It's still heart surgery
    Raytheeagle and padroo like this.
