Engine swap question
Discussion in 'Gen 3 Prius Technical Discussion' started by cnc97, Jun 29, 2018.
  1. padroo
    padroo Senior Member
    2,763
    2,253
    It's always good to have choices.
  2. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    When the choice is A: $1200 150k mile Gen 3 engine or B:$1000 8k mile Gen 4 engine that needs “massaged” or reusing “repaired” Gen 3 head, I think the obvious choice is the lower mile short block. At least it is for me.
    m.wynn likes this.
  3. JC91006
    16,936
    8,647
    Until you say to yourself "never again"
    Raytheeagle likes this.
  4. ASRDogman
    ASRDogman Senior Member
    8,063
    4,086
    Well, if someone has some extra cash, and time, they could buy a few Gen 4 engines and convert them to the Gen 3.
    They sell them ready to install!
    JC91006 and Grit like this.
  5. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Shhhh, the price on Gen 4 engines just went up!! LoL
  6. Ragingfit
    Ragingfit Active Member
    189
    249
    Aurora, IL
  7. Ragingfit
    189
    249
    Aurora, IL
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Very cool, was that you’re project?
  9. Alltwocents
    Alltwocents Junior Member
    ALABAMA
    Luxury
    Thanks guys,
    I took the info and jumped on a 1k mile 4th gen motor for $800.
    The swap is going nice. Hope to have it running tomorrow.
    Ragingfit, Shane Burns, RMB and 3 others like this.
  10. Threej
    Threej Member
    99
    99
    Portland, OR
    Still waiting for the anecdote of taking the frankenprius to the dealer for an oil change :-D
  11. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Approaching 3000 miles on mine and not a hint of an issue at all. Showing 53.5 mpg on the HSI and that’s driving in Normal mode. No measurable oil loss or coolant usage.
    amos, Shane Burns, m.wynn and 2 others like this.
  12. Shane Burns
    Shane Burns Member
    94
    126
    SoCal
    Now I kinda want to buy a Prius with blown head gasket and swap 4th Gen engine in it!! I miss my Prius already! :oops:
  13. amos
    amos Active Member
    376
    285
    los angeles
    @cnc97 i salute you for the courage and thibking out of the box.
    I read most of your threads and wanted to ask you for a summery of all items of the swap which were not identical and next to each one a summery of how you took care of it.like the dipstick etc... Hoping its not too time consuming for you
  14. amos
    amos Active Member
    376
    285
    los angeles
  15. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    On my swap, I used my Gen 3 head. New head gasket and bolts. I reused the valve cover gasket from my engine. There’s an issue with FelPro and their part numbers for the Gen 3 motor. The only things correct in the entire head gasket set were the head gasket, exhaust manifold gasket, intake gasket, and the valve seals. The other miscellaneous gaskets in the set were wrong. I reused the EGR gaskets, water pump gasket, throttle body gasket, thermostat gasket.
    I used the chain and gears from the Gen 4 engine. Also the cams. New tensioner though. Timing cover and valve cover are Gen 3. I did buy a can of high temp black wrinkle finish paint for the valve cover. Gen 4 coils were a direct fit. Also Gen 4 fuel rail and injectors. However the rubber hose from Gen 4 fuel rail is different. The vehicle side connector is different. Use the rubber hose with connector from the Gen 3 motor.
    If anyone within 75 miles of Evansville IN has a need for a Gen 4 head, valve cover, intake, and some other miscellaneous hoses, drop me a PM. It’s taking up space, but it’s too valuable to just throw away. The head is missing one cylinder worth of valves.
  16. Ragingfit
    189
    249
    Aurora, IL
    #216 Ragingfit, Sep 23, 2018
  17. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    Do you know if the ecu's are programmed the same? Could be kind of like 1st and 2nd gen 1.5L engines. Same size, but I think there are differences in the programming, VVT, and etc. Of course that is not rock solid assurance speaking though. I could be mistaken. Just saying, it's worth considering.
  18. Mendel Leisk
    42,341
    Memorable quotes:
    "...you're looking at the part you wanna remove; just go ahead and remove it, yah know..."
    "...you're gonna be looking at this wire through the whole process, thinking: what do I do with this wire..."
    "... make sure you don't break the glass, cus this will be right where you don't want it, for this whole process..."
    "...if you're going to be hyper: don't be hyper there..."
    "...on the floor: the car's got leather, it doesn't get to sit on the seat..."
    Thank you, really good video, funny, invaluable tips, saving this. (y)
    Particularly like how you stay organized, the drawers and sticky notes. And the prep: things to do before you disconnect the batteries. And to take pictures/videos before you start pulling stuff off.
    The cowl and wipers sounds very similar to regular 3rd gen hatchback btw.
    Big question: the video is "part one". Going to YouTube I didn't see subsequent parts. Are they there, or are you still editing? Really like to see it through.
    This should be stickied, once the dust settles? @Tideland Prius ?
    #218 Mendel Leisk, Sep 25, 2018
  19. Ragingfit
    189
    249
    Aurora, IL
    There are 8 parts, (about 3 hours edited) so far, on YouTube. Editing is time consuming, and no "do overs" on this, yet. More to come - the engine installation videos will go up as they are edited. And please forgive the quality and sometimes the noise. Next time, the compressor will go outside.
  20. Ragingfit
    189
    249
    Aurora, IL
    I took it on faith that mine would run as a Gen 3. On the Gen 4, there were changes to the engine, trans-axle and ECU/PCU, but there is no need to change the ECU/PCU.
