Engine swap question
Discussion in 'Gen 3 Prius Technical Discussion' started by cnc97, Jun 29, 2018.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Pressure washer;).
  2. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    I did but still the water is not flowing freely. I will try oxy clean dish powder to see if it helps. I am going to take apart the one that came with the engine to see how it looks and water flow rate to compare it
    Raytheeagle likes this.
  3. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Definitely compare the two and the lower mileage one should be easier to clean;).
    What tip are you using on the pressure washer gun:whistle:?
    I use the most focused spray pattern and hit every passage. If you are getting flow, you’ll be able to blast through it with a directed force:).
    Good luck and keep us posted (y).
    Apatel1101 likes this.
  4. ASRDogman
    ASRDogman Senior Member
    8,063
    4,086
    The OVEN CLEANER will EAT the carbon. It will make it mush. Then you can blow it away with the pressure washer.
    But feel free to clean it 5,10,20, etc. times with soap. $3 for a can of oven cleaner. 30 minutes for it to work.
    Maybe longer since it's so clogged...
    But your decision....
  5. Mendel Leisk
    42,341
    Oven cleaner might do it; it's further towards the basic end of the PH spectrum than Oxi.
    if all else fails, a new cooler is around $200~250. Or buy a salvage cooler for about $100, hopefully in better shape, more cleanable.
    Apatel1101 and Raytheeagle like this.
  6. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    He already has a spare on the new engine ;).
    Both can’t possibly be to the point of no return :cool:.
    Send them to me and I’ll send you my clean spare (y).
  7. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    For last time i soaked it in 3 part degreaser and 1 part hot water. Let see tomorrow then i will try oven cleaner. I just saw it while washing my hands(didnt know we had one).
    mjoo likes this.
  8. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    I have harbor freight power washer and its on finest setting (i guess thats what its called) i will try again after i use oven cleaner. Which side should i power wash from. The vapor comes from exhaust manifold side then to the intake so back washed it once. Should i do the same or do it wise versa?
  9. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Both @Mendel Leisk and I used a degreaser before the oxiclean to clean out our coolers. Maybe that's the key.
    Pixel XL ?
  10. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I have the 14 year old version of that:).
    I clean from both sides. If one side is posing an issue, I’d hit it from the other side;).
    Eventually you’ll break through and both sides will flow freely(y).
  11. Mendel Leisk
    42,341
    Really? I was picturing this rip-snorting gas-powered behomoth. I keep seeing your EGR coolers braking loose from the deck chair, and launching...
  12. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    The Harbor Freight “back in the day” brand was Wheel Horse. It is red and puts out 1700 psi running off of 120 power:).
    Small and compact, just right for Suburbia and having a good tool arsenal(y).
  13. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    I still cant see through it and doesnt flow freely. I am going to try oven cleaner.
  14. Mendel Leisk
    42,341
    Yeah, and I think @Raytheeagle is on the right tact: shoot it in both ends. Did you manage to run a wire through, can't recall.
    #274 Mendel Leisk, Jan 14, 2019
  15. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    I dont have small wire that would fit in there
  16. Mendel Leisk
    42,341
    I found a regular coax cable wire just fit. There's a thicker gauge coax also, might be too thick.
    You need to file the tip, take any burr off, and kind of rotate it this way and that, bit of a labyrinth that can snag it.
    mjoo likes this.
  17. padroo
    padroo Senior Member
    2,763
    2,253
    If you don't have a pressure washer take it to the do it yourself car wash, worth a try.
    The trick to any job is having what you need on hand before you start the job.
    Robert Holt and Mendel Leisk like this.
  18. Ragingfit
    Ragingfit Active Member
    189
    249
    Aurora, IL
    Hey Apatel1101, You do live close.
    Sorry I just read this Monday noonish.
    It looks like you got lots of good advice form the group.
    It also looks like you got 3 broken bolts out of your trans with your FatMax and a torch.
    Nice work!
  19. Ragingfit
    189
    249
    Aurora, IL
    I really like Berryman's
    padroo likes this.
  20. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    Whats the part called or part number for the cover that goes here. Spent half an hour at toyota parts. They also cant find the two smaller bolts that hold that plate
