Engine swap question
Discussion in 'Gen 3 Prius Technical Discussion' started by cnc97, Jun 29, 2018.
  1. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    How do we get techstream?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Mini Vci or VXDIAG on Amazon has Techstream paired with it ;).
    You’ll need a laptop to run Techstream, but they’re are plenty on Craigslist :).
    Good luck (y).
  3. Joele3
    Joele3 Active Member
    138
    206
    Bay Area
    Put a new thermostat in. Had the tank raised to get all the air out. I’m watching the temps increase. Touch all the hoses, getting hot. The hose that never gets hot finally got hot (passenger side). I start revving the motor temps staying steady. I put the tank back to original spot. Shut off out of maintenance mode.
    Start up go for a short drive. Cruising, temps going up. Ok let me smash on the gas, temps jump up quick! I ease off coasting back home. I let car cool down. Check all hoses no leaks. Start back up waiting/ revving motor. Boom check engine light comes on water pump code. New water pump 2016 model. I pull off the water pump. Propellers are seized up. So maybe the 2016 water pump just doesn’t like the 2010 ecu. I put my old water pump back on with 30k miles. I’ll report back once I get some more coolant.
    No steam no temp light just watching the temps from obd scanner.
  4. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    @cnc97
    @Ragingfit
    @Raytheeagle @Mendel Leisk
    So i started my prius after 16 days of non use. I start it today to change pads and rotors. I got multiple lights on dash. I drove about 25 miles now and it still doesnt go away. I checked 12v battery its reading 12.8 like 2 min after shutting off. Should i check voltage in morning? Battery was installed 12/17 at toyota dealership
    Lights currently illuminated
    Check hybrid system
    Skid
    Yellow triangle with exclamation mark
    Brake
    Abs
    Power steering
    #364 Apatel1101, Feb 27, 2019
  5. Mendel Leisk
    42,362
    Orland Park is a suburb of Chicago, Illinois? This time of year 16 days downtime with no battery minder will have an impact, not sure how much. The car imposes a low level but constant demand on the 12 volt.
  6. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    Would you recommend getting a new battery to check if the lights go away? The car started right away without hesitation. I know brius doesnt have starter like normal gas powered cars.
    The weather here is around 6-35 farenheit
  7. Mendel Leisk
    42,362
    Maybe just disconnect/reconnect the neg cable first, see if that clears it?
    You're talking to a guy that has a CTEK 4.3 charger nearly constantly hooked up, commencing any day the car's not going anywhere, and left on until such time as the car is used.
    We're just flirting with freezing here on the coast, overnight, at the worst, around 32F. Sometimes a few degrees lower.
    Raytheeagle likes this.
  8. Ragingfit
    Ragingfit Active Member
    189
    249
    Aurora, IL
    If you can read the codes, diagnosis becomes easier. A bunch of lights on the dash are just scary and I don't know what they mean.
    Your 12 volt battery is in normal range. It's only used for the electronics, computers, and accessories of the car.
  9. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    The torquepro app doesnt show any so i am going to get it checked at autozone or advance auto.
    Also my speedometer shows 0mph and energy monitor doesn't work. No consumption mpg either.
    My right fender liner(driver side) went missing. It was loose and there when i parked. I go back after more than 2 weeks its missing.
  10. Ragingfit
    189
    249
    Aurora, IL
    I had an ELM327 bluetooth OBD 2 scanner that made my ABS go crazy on 3) of my Prii.
    The "no MPH" thing sounds like a combo meter problem, but I'd resolve the bluetooth torquepro scanner issue first.
    No problems before the ELM 327.
    I had to reset my car with an Actron OBD 2 / ABS scanner to make my ABS codes go away.
    I tried it on 3 different cars, all prius's. I know it was the Torque Scanner.
    Thanks for the update.
    My Gray V has been flashing the temp light a few times a day since I changed my antifreeze.
    It's funny cause I did the swap in the summer and had no problem then.
    At least you know what's wrong with your car. Fingers crossed.
    I'm going to change out my pump and thermostat soon.
    #370 Ragingfit, Feb 28, 2019
  11. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    Every time i press brake, it makes buzzing noise and it doesnt record miles driven on trips. It drives normal (starts and stop at red light). I went to autozone and advance auto but they dont have abs capability even tho they had same actron obd scanner
  12. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    So I disposed of the remains of my blown engine today. I removed the lower oil pan to drain the milky mess left over. I found the majority of the skirt from the number one piston, the wrist pin, and nearly two inches of a second connecting rod. So apparently my engine was attempting to toss a second rod when it stopped turning.
    I just wish that it had happened during the daylight when it blew up. I bet there was a glorious smoke show when it grenaded. Since there were no takers, the Gen 4 head did go with it. However I did keep the Gen 4 intake manifold.
    Ragingfit, m.wynn and Mendel Leisk like this.
  13. a_gray_prius
    2,927
    783
    IL
    We're like within 20 minutes of this guy and we've had cars out in this polar vortex for more than 16 days and they've been OK. Our Prime sat for almost a month during the last polar vortex.
    On the other hand, you could have the kind of show a lot of RSX guys got when they "money shifted".
    #373 a_gray_prius, Mar 7, 2019
    Ragingfit and Mendel Leisk like this.
  14. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    The results are in. The analysis says put more miles on it and retest.
    FnRedPrius and mjoo like this.
  15. FnRedPrius
    FnRedPrius Active Member
    100
    121
    Pilot, NC
    How many miles did your donor have at install? I had changed earl in the beast 2-3 weeks before engine swap and I didn't bother to reset the reminder. Between that and the 810 miles past the first oil change on the donor it should be right which back on schedule. I have the kit and if I may send it in just to start a baseline and send them every other oil change.
  16. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    The yard told me 12k on the odometer is what they had in the computer. The overall condition of the engine said that may have been a high estimate.
  17. Randycoureton
    Randycoureton Junior Member
    US
    Four Touring
    Does anyone know is a 4th gen motor will interchange with 3rd gen. I know the fuel air delivery system is different but the blocks look the same. Has anyone actually swapped one out?
    Everything looks the same. I got two 2016 motors and the valve cover and the fuel air delivery system is different but the blocks look the same
    #377 Randycoureton, Mar 28, 2019
  18. Randycoureton
    US
    Four Touring
    Yes they changed it somewhat
    Both blocks say 2zr
    #378 Randycoureton, Mar 28, 2019
  19. Randycoureton
    US
    Four Touring
    To answer my own question. The coolant housing is different coming off the back of the head. Every thing else seams to be interchangeable to make the swap possible. If anyone comes up with a adapter for it I'd be interested
  20. Ragingfit
    189
    249
    Aurora, IL
