Engine swap question
Discussion in 'Gen 3 Prius Technical Discussion' started by cnc97, Jun 29, 2018.
  1. padroo
    padroo Senior Member
    2,763
    2,253
    Yea, a lot of the Gen 3 Prii have got to have a ton of miles on them. Some newer cars you can only put the same year motor in them I have been told, especially if your car has to be pollution inspected.
    OP lives in Evansville Indiana and no emissions testing there. Just two counties in Indiana have it and I am lucky to live in one of them, lucky me.
    #21 padroo, Jul 2, 2018
  2. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    So according to the dealer, Gen 4 uses silicone gasket maker for VC gasket. No actual gasket. But the cylinder head is the same part number from 10 to current. There have been three revisions to the head gasket. Dealer says that the mechanics of the engines is the same. Subtle differences in PCM calibrations give the 16 and newer engines 40% volumetric efficiency. Versus 37.5% on the 10-15 engines.
    LKQ will give me 100% refund if the engine is not correct. Their interchange says that it will work. They do say to use all the sensors and external parts from my old engine to keep the electronics happy. Seems that there is an almost endless supply of low mileage engines in the LKQ inventory.
    mjoo likes this.
    52,863
    sounds possible...
  4. padroo
    2,763
    2,253
    Good luck on your project, keep us informed.
  5. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    So another week down in the search for the right engine. I have noticed something very peculiar. I have been in touch with LKQ on a couple of occasions. The following has caught my attention. Gen 3 engines, even lunar mileage ones are getting premium prices. But, especially in Cali, which I would gladly pay shipping to Indiana on, a Gen 4 engine can be had for as little as 800 dollars. Compared to prices on the Gen 3 in Indiana are 1250-1700. Does anyone have any insights on this? It makes no sense to me, but maybe someone else can understand it.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Supply and demand;).
    But to answer your question in a different way, have you explored other sources other than LKQ?
    I’d look at some of the ones on eBay or a local salvage yard and see what they have.
    The gen4 didn’t end up working out in your situation?
  7. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I’m still not entirely convinced that a Gen 4 couldn’t be used in a 3. Problem is that no yard in a 200 mile radius of me has a Gen 4 out on a pallet or shelf to lay hands on. I had a Gen 3 that did not pass a leak down test. I have a portable compressor and the hose to my compression tester that I used. Found a blown head gasket on the engine I was ready to buy with cash in hand.
    SFO, Aaron Vitolins and Raytheeagle like this.
  8. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Good to come prepared ;).
    That will be the problem with a Gen3 as most owners are not aware to check for certain design challenges and then the unfortunate happens.
    Some of these have wrecks and then the engine ends up “available to others”.
    Smart decision (y).
  9. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    A shop near me has a Gen 3 engine that tossed a rod out and on a pallet. I took some pictures of the mounts and such. The pictures of the Gen 4 engines on eBay and other sites put mount flanges and sensors in similar locations.
    The yard that had the Gen 3 engine I was looking at disassembled the engine that I was going to buy. It got tossed in the scrap bin. They wouldn’t even let me buy the short block. I’d have thrown a head gasket on it, but the yard owner said that he’d rather not try and find me another engine in 90 days.
    Raytheeagle likes this.
  10. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I do know the intakes are different, but sealed with the same o-ring style gaskets. The exhaust manifold is different due to change in EGR tubing exit from converter versus manifold. The valve cover has a vent(?) below and forward of the oil cap the Gen 3 doesn’t have. However that is under the engine cover that sits farther forward of the Gen 3 cover.
  11. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Wow:(.
    The joys of living in the fly over states:cool:.
    Out here there are 3 salvage yards with 50 miles and LKQ in the area. Also fortunate enough to live in the land of Prii, so salvage parts are plentiful;).
    I know Auto be yours is a ways away, but it might be worth looking him up and seeing what he could do for you.
    Good luck on the quest(y).
  12. bisco
    52,863
    just get a gen 4 and go for it. where's your sense of adventure?:cool:
    amos, Mendel Leisk and Raytheeagle like this.
  13. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I bet time and money are key inputs into the adventure equation ;).
  14. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    If I was 95% sure it would fit, it would be on my engine stand getting parts changed over. As it stands I’m at 65%. I’d like to put my own eye on it to see. I am thinking of visiting a Gen 4 and doing my own underhood inspection. Not sure how my local dealer will respond, but I’ll take that chance.
  15. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Good plan;).
    Good to see you are coming around:
    Good luck with the inspection (y).
  16. padroo
    2,763
    2,253
    Give this company a call, they specialize in Gen 2 Puii, I know you have a Gen 3 but maybe they can help you and they are at least in Indiana.
    04 and newer Prius Parts Cars
    150 miles from you.
  17. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Holy hell! I’m going to have to drive over just to look at some of their custom work. A Pruck as they call it, a couple of Gen 2 limos. A boat-Prius. Wow. Now I have seen it all.
  18. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I was there in February as I was on a business trip to Indianapolis:
    Definitely a unique experience but they have ALOT of parts(y).
  19. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    They have several damaged Vee Prii on their site too. Some of them maybe terminal, but not engine end damage. Fallen trees and rear end damage. Might be worth a look.
  20. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    It’s probably only 2.5 hours away:).
    Worth a call and chewin the fat to see what’s there and pricing (y)
