Engine swap question
Discussion in 'Gen 3 Prius Technical Discussion' started by cnc97, Jun 29, 2018.
  1. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    You can do as @Ragingfit did, and use the metal pipe to adapt the lower hose, and lengthen the one sensor harness. Or you can do as I did. Disassemble both the Gen 3 and 4 heads, and use the Gen 4 valves, springs, etc to rebuild the Gen 3 head. Six to 1, half a dozen to the other. Mine is very close to 10k miles and has not used a drop of oil or coolant. I’m very pleased with the result.
    Robert Holt likes this.
  2. Mendel Leisk
    42,341
  3. FnRedPrius
    FnRedPrius Active Member
    100
    121
    Pilot, NC
    I did ours about a month ago. Not really a big deal. @Ragingfit has a video series on Youtube under fix that Prius on the swap. @cnc97 led the way with the first one. I used a donor from a wrecked 2017 with 5,810 miles.
  4. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    @Randycoureton i used a 1-1/4 coolant line from advance auto because i couldnt find metal pipe in that size. And i used this adapter for the two hoses to connect.
    Robert Holt and Ragingfit like this.
  5. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    This was today’s excursion to check the underside of the throttle body. I did drive 2500-2800 miles after install before I put the catch can back on. Just a light oily film that wiped clean with a single shop towel. Still no oil usage and no coolant loss.
    Robert Holt, RMB, Raytheeagle and 2 others like this.
