Engine swap question
Discussion in 'Gen 3 Prius Technical Discussion' started by cnc97, Jun 29, 2018.
  1. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Pictures and video will be documented. It will be a game changer for all with higher mileage Gen 3.
    bisco, Raytheeagle, RMB and 1 other person like this.
  2. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Bonus points if you keep the GEN 4 improved EGR system.
    Pixel XL ?
    RMB and Mendel Leisk like this.
  3. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    If I get one with the converter and EGR pipe I will try and use it.
    mjoo likes this.
  4. padroo
    padroo Senior Member
    2,763
    2,253
    Do you have another car you can drive while you are doing a switchover? It won't be a weekend project.
    If all goes well I can see Gen 3 Prius owners buying a cheap low mileage Gen4 engine and have it sit around until needed. It doesn't sound like you could loose any money on it as the Gen4 gets older the price should go up.
  5. Mendel Leisk
    42,296
    At first read I thought you meant the whole car, but it's still engine swaps?
    In OP's shoes, I think I'd roll the dice on anything between 2010 and 2015, but not 2016+: bound to be problems.
  6. bisco
    52,803
    who doesn't like a challenge?:cool:
  7. padroo
    2,763
    2,253
    I did an engine swap many years ago in a Triumph GT6, the old engine lost its thrust washers into the oil pan and it would have taken reworking the engine block and crankshaft so I went to the junkyard. I found another engine in a newer Triumph and not a GT6 and back then there wasn't the information around like the internet and no one could tell me if it would fit. I changed the engine and everything bolted up fine and it ran. I had the bonnet off and installed it but the bonnet would not close because they hit the carburetors. I ended up punching a couple of holes in the bonnet and made a fiberglass bubble in the hood and all was well.
    Robert Holt and bisco like this.
  8. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Yes I have another vehicle to drive while the Prius is apart. Got to get the Prius back up. Uber+4.6 Explorer=Doesn’t work
  9. milkman44
    milkman44 Active Member
    591
    386
    Ky
    I'm only 80 miles away, wouldn't mind to be a goffer or extra hand or set of eyes for a day, or picture taker or video camera holder. 80 miles is not that far in a hybrid.
    SFO and Raytheeagle like this.
  10. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Now that I am sure enough to up and go for it, I am narrowing down the choices on where to get my engine. Most of the ads show the intake and exhaust manifolds on the engine. Trying to see who sends what with the engine at what price.
    mjoo likes this.
  11. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    1200 gets me intake and exhaust with the EGR. And it’s 3 hours one way to drive. They wanted $100.00 to strap it to a pallet, plus truck freight to me(about 200). I can go pick it up for roughly 125. So I think that is my plan.
    Shane Burns and mjoo like this.
  12. Rmay635703
    Rmay635703 Senior Member
    2,688
    1,725
    Somewhere in Wisconsin
    2013 Chevy Volt
    Last engine I picked up I threw in the back of my Insight,
    You must only get 10mpg?
  13. Mendel Leisk
    42,296
    Just Googling, a typical 4 cylinder engine is about 300 pounds.
  14. Rmay635703
    2,688
    1,725
    2013 Chevy Volt
    A Prius isn’t, a bigger guy can carry one around
  15. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I’m going to make a day trip of it. Food and incidentals.
    bisco and Raytheeagle like this.
  16. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    That’s why I’m working on it Wednesday and Thursday on my days off. LoL
  17. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    They took EGR cooler and manifold. But the rest is there. Now the fun begins.
    RMB, mjoo and Raytheeagle like this.
  18. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Would be nice if they included the exhaust manifold and the cat (or pay a little extra to have them) so you can play with an EGR system upgrade fitment.:p
  19. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I got mad. They were taking stuff off AFTER they had my money. I told them to stop stripping it or give me my money back. Coils, flywheel, transaxle damper and intake came home with me. They only got the EGR cooler and manifold with converter. I am tempted to try and use the intake manifold.
  20. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Here it is mounted on a stand. I’m going to clean it up a bit before the install.
    sega64, RightOnTime, padroo and 7 others like this.
