Engine swap
Discussion in 'Gen 2 Prius Main Forum' started by Dbryant1732, Jul 5, 2018.
  1. Dbryant1732
    Dbryant1732 Junior Member
    40
    Clarksville, TN
    Within the next week to 2, I will be replacing the engine in my 2006. I have, over the years, done several swaps-just never on a hybrid, nor a Toyota for that matter. Any recommendations will be appreciated. I am just trying to get some advice before I tackle this project.
    Thank you!!
    padroo and Paul Schenck like this.
    52,855
    read through the engine replacement threads. first thing that comes to mind is deciding out the top or bottom. tranny, or no tranny.
    all the best!(y)
  3. Dbryant1732
    40
    Clarksville, TN
    Thanks man!
  4. way2coolwheels
    39
    42
    I recently did an engine swap in my 07. I was a little apprehensive, like you. But it was actually pretty easy once I got into it. Once you remove the wiper/cowl, you can access everything much easier. You will have to remove the inverter, so be sure you disconnect the batteries. The inverter is liquid cooled, so expect a little coolant loss from it as well as the engine. Even though both use the same coolant, they are separate cooling systems. Make sure you get the correct coolant to refill it with afterwards. There is no torque converter to deal with, so when the engine is unbolted from the transmission, it's pretty easy to separate. The only difficulty you might experience is the very tight fit between the right fender and the transmission case when removing the engine, but it can be done with a little persuasion by large screwdrivers or prybars.
  5. Dbryant1732
    40
    Clarksville, TN
    Where you able to do the swap through the top or did you go through the bottom? I still have not had the time to mess with it yet, we have a few other swaps we are doing for other people. Have a 74 Ford and a Lincoln MKX that we are having to put in new engines, so mine is on the back burner for now. Hoping to at least get started this weekend though.
  6. way2coolwheels
    39
    42
    I removed it from the top. You'll need to support the transaxle with a floor jack from the bottom and tilt it upward to assist the engine clearing the bell housing. And like I said, a very tight fit between the bell housing and the fender. Remove the waterpump pulley and the crank pulley to make it easier.
    Patrick Wong likes this.
  7. way2coolwheels
    39
    42
    #7 way2coolwheels, Aug 2, 2018
  8. Dbryant1732
    40
    Clarksville, TN
    Awesome!! Thanks man! I do really appreciate the advice and the picture. Does seem easy enough. I will definitely update you on my progress with this!
  9. oil_burner
    oil_burner Active Member
    249
    126
    Hi all I'm also getting ready to do a swap. I wanted to see if any specific tools required besides pry bars and an engine hoist?
  10. padroo
    padroo Senior Member
    2,763
    2,253
    I haven't done a Prius either but a good scissor jack and some block of wood are always a good idea to have around.
    I assume you have a floor jack.
    Safety first, pull the plug on the HV battery and disconnect the 12V battery.
    Someone on another post said to roll the windows down and block the hatch from locking before you disconnect anything.
  11. oil_burner
    249
    126
    Ok I sourced a junkyard motor, and plan to take it out through the top. Did you guys have to disconnect the exhaust manifold to have clearance to pull the motor out?
  12. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    Hope it goes well, the two times I did it, I dropped the engine down on a sheet of plywood and lifted the car up high enough to slide it out from under the wheel well. I did it all myself with a 2x4 and some straps from harbor freight the first time and my daughter helped the second time gettin it done in a day. Compared to the weeks it took to do my 1968 Mercury Cougar XR7 from the top back in 1977 it was sooo easy! I used a Hains manual and a video on UTube. The hardest part was the 30 mm 12 point socket for the front axels and the Transaxel connectors.
    iPhone ?
    TranquiloQuieto and Aegean like this.
  13. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Did you drop the entire transaxle then split the engine from the transmission?
    Paul Schenck likes this.
  14. oil_burner
    249
    126
    do you mean you did it without an engine hoist? how did you lift the replacement engine off the ground?
  15. Skibob
    2,912
    1,505
    Northern California
    You can drop a smaller transaxle down without an engine hoist if you have a block and tackle connected to a beam in the garage. They are not that heavy. Heck I could lift the engine and transmission from my old Nissan Sentra by myself.
  16. oil_burner
    249
    126
    thanks that seems like an easy way to do it, I have never removed an axle before. how is it secured into the transaxle besides the big nut on the hub? Does the suspension arm have to be removed as well?
  17. Paul Schenck
    524
    307
    Fresno, California
    Yes, it was super easy and nicely balanced
    The first time I did it I took Patrick Wong’s ad vice and got both engine and Transaxel ( bought a totaled 2006 for $1000 with 80,000)
    The second time since I knew the sequence and how easy it was and had taken lots of pictures and notes we had that engine and Transaxel out on the floor in less than three hours, rolled it around on a moving blanket to take out the bolts that mate them together and carefully separated them.
    iPhone ?
    oil_burner likes this.
  18. oil_burner
    249
    126
    was it faster to take them out together rather then unbolting only the engine and dropping that? Would you care to share some of the pictures with me? Thanks
  19. Mendel Leisk
    42,347
    Full disclosure, I never done this, purely armchair mechanic musing:
    I think the bees knees is a hoist above, especially one that is on a trolley, capable of moving fore and aft about 6 feet, so you can lift straight up, then bring it forward clear of the front bumper. And hopefully the setup doesn't collapse your garage roof.
  20. Paul Schenck
    524
    307
    Fresno, California
    Two of those ratcheting straps from harbor freight pulled it right up off the ground and then large hydronic jack to hold it while I re adjusted them. Let me find a picture
    iPhone ?
