Engine swap
Discussion in 'Gen 2 Prius Main Forum' started by Dadinmt, Apr 19, 2020.
Tags:
  1. Dadinmt
    Dadinmt Junior Member
    Montana
    At auction I bought an 07 as a run and drive hail damage. Long story short the engine has holes in the crankcase from rods that aren't doing what they are supposed to do.
    I have access to an 2010 model that has a good engine.
    Will the 10 fit and work in the 07? Or should I just scrap it and kiss the 4k goodby?
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    strawbrad, dolj and Raytheeagle like this.
  3. dolj
    dolj Senior Member
    8,648
    4,398
    Wellington, New Zealand
    I wouldn't scrap it, do as SFO says. For a Gen 2, you should be spoiled for choice and not very expensive at that, especially if you can do the swap yourself.
  4. Rmay635703
    Rmay635703 Senior Member
    2,704
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    GEN II motors used to run $75+ from the yard, they have inflated slightly but still priced well.
  5. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Good LORD GenII's are expensive in Montana!
    Given what you have into it, replace the engine, like-for-like (GenII).
