Engine swapped, now car wont become ready
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by brownsnoutuk, Dec 13, 2011.
  1. brownsnoutuk
    brownsnoutuk Active Member
    185
    119
    Shepherd, TX
    Im having some issues after swapping the engine on my 05. The swap went well and i hooked everything back up the way it was. I have triple checked every connection. If I am missing one then it is hidden extremely well.
    I reconnected the HV and Aux batteries but the car will not go into ready mode. All the warning lights come on and the screen shows problem!
    The inverter coolant pump is running, my basic obd2 scanner shows no codes.
    Im hoping someone can suggest things to check before I have to get it towed to Toyota. Can I buy a scangauge that will tell me the hybrid trouble codes?
    Any help would be appreciated. Thanks
  2. Patrick Wong
    18,210
    6,517
    A simple thing to check is the orange traction battery interlock switch. When reinserting it you must pivot the lever 90 degrees. Then you must slide the switch to lock it in place.
    You can buy Toyota Techstream Lite software to run on your laptop. However it would be probably much cheaper for you to tow the car and pay the $100 or so to have the dealer tech tell you what codes are logged and provide a diagnosis.
  3. brownsnoutuk
    185
    119
    Shepherd, TX
    That was it Patrick, thank you so much. I was forgetting to slide the switch up. I feel pretty dumb right now, but man you saved me a trip to the dealer.
    :D
  4. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Most people worry about replacing the battery.
    How's it performing with the new engine?
  5. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    If: We could only calculate the amount of money that Patrick has saved with his precise and great advice. Three cheers for Patrick! :cheer2:
  6. brownsnoutuk
    185
    119
    Shepherd, TX
    Its running great, thanks again Patrick.
  7. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I'm curious why the engine had to be replaced, and at what mileage...
  8. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    Cheer3!!!
    Can't believe no one get this. :)
