Engine Temp Info/Gauge
Discussion in 'Gen 3 Prius Main Forum' started by knite75, Jul 8, 2013.
  1. D McDonald
    D McDonald New Member
    While the Scan Gauge can program, I don't know how, nor do I know the codes and their purpose. Also, I would be wary of changing any codes while the car is under warranty. I kind of like the appeal of the UltraGuage. granted it is just reading the passive codes but what else do I need? In any case I want to be able to exchange the unit between vehicles as I really have more use for it in the other vehicle.
  2. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    You can easily move the Scangauge from vehicle to vehicle.
  3. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    I've owned a 2009 Civic Hybrid and 2012 Prius. Both cars had oversized radiators for such small engines. Neither burned any oil. I wouldn't say it's impossible to overheat the engine, but it's very difficult. You would probably have to sustain redline rpm for several minutes to get the oil too hot. In both cars, I've never seen coolant temps over 201°F/94°C.
