Engine Temperature, Warm-up, Heater questions.
Discussion in 'Prime Main Forum (2017-2022)' started by MarkOlin, Jan 2, 2020.
  1. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    My climate control stays at whatever the setting I set last. Are you using "AUTO" ? If so, the direction of air flow is controlled by the car. To override it, you have to first turn off "AUTO", and then select the Dash only, Dash and Floor, Floor only, or Window+Floor, air direction and set the fan speed to desired level manually. You can turn off the Climate control by hitting the Fan OFF button, and turn on the Climate by turning fan level up. If you have the LE model, the switch maybe different from the 11.6 display shown below.
    #21 Salamander_King, Jan 6, 2020
    john1701a and jerrymildred like this.
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    "Brrrrr!", says fotomoto typing this in shorts and t-shirt. :whistle:
