Engine temperature
Discussion in 'Gen 3 Prius Main Forum' started by livein, Sep 22, 2009.
  1. fuzzy1
    10,707
    Go to ScanGauge's Toyota-specific support page, which happens to point back here to PriusChat and to CleanMPG.com.
  2. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
  3. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Modern engines mostly have cooling systems that flow through the heater all the time, using flaps to guide the air rather than stopping the coolant flow through the heater core. Although you can't dump the heater core into the system, turning the heat on will still have a cooling effect as you described, due to the extra fan in the heater, but not to such a great degree.
    ThePrius11 likes this.
  4. ken2116
    ken2116 Junior Member
    40
    17
    Northern CA
    2019 Prius
    Many reasons to show engine temperature:
    1. Knowing when the engine is warmed up and it's safe to accelerate harder, if desired.
    2. Indicating when one is creeping above normal operating temperature, such as when climbing a long hill at high altitude on a hot day, in time to turn off the AC and turn on the heater, or slow down.
    3. A wide variety of incipient problems often are indicated by anomalous temp gauge behavior, giving time to address them before they leave one on the road. The same goes for knowing ones oil pressure, oil temperature, and charging system voltage.
    Given the choice, I'd much rather have the above information than the cost per gallon calculator and some of the "feel good" mileage history indicators.
    ThePrius11, davecook89t and CR94 like this.
  5. ken2116
    40
    17
    Northern CA
    2019 Prius
    What do you consider "better oil", higher viscosity? How high can one go?
    CR94 likes this.
  6. dominicIOWA
    dominicIOWA Junior Member
    Iowa
    I use a Bluetooth obdII dongle plugged in and use the torque app on my phone to monitor temps and other things.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Pulease, just drive it.
  8. Mendel Leisk
    42,347
    I found coolant temp informative. It's in there, would love to see it displayed on the dash. In the intermim, ScanGauge or myriad phone apps in conjunction with a OBD dongle can show it. Still, I don't think the OBD port is designed for constance connection; I started getting error messages on the dash (Check Hybrid System) so discontinued use.
  9. CR94
    CR94 Senior Member
    2,830
    1,243
    Northwestern S.C.
    I have had my Scangauge connected over 4 years and have never seen such complaint from the car.
  10. ChapmanF
    19,024
    ThePrius11 and Robert Holt like this.
  11. Robert Holt
    Robert Holt Senior Member
    1,313
    890
    I’d agree with Ken2116, because when I tried storming up the ridges of the Appalachians at a constant 70 mph, the Scanguage II reported ICE coolant temp rising slowly to 204 degrees Fahrenheit, which is noticeably higher than the normal 194-196 range. Slowing down to 60 mph for the next ridge climb kept the coolant temp under 200, so that info helped alter my driving tactics.
    Similarly, when the #2 HV battery temperature sensor gets over 40 degrees Celsius and the battery fan motor goes to level 4 or 5, I try to avoid any sharp charging or discharging from the HV battery to try to moderate those higher battery temps.
    (This can be interpreted as either simple obsessive-compulsive disorder, or just a residual habit based on continuously monitoring aircraft systems whilst flying over many years, but some types of complex , human-controlled systems do better when monitored for boundary conditions.j
  12. pree_us
    pree_us Member
    64
    97
    Santa Clarita
    Here's a photo of my using the "base" (aka free) Torque App on my aftermarket 9.0 Android HU . . .
  13. Tyler Theobald
    Tyler Theobald New Member
    Omaha, NE
    I have 4 3rd Gen Priuses, and one of them had recently used up a large portion of the engine coolant, with none left in the reservoir tank, due to a head gasket issue. I suspect the coolant temps were creeping up at some time due to this and I'd like to have caught it early. I'm trying to find a good ODB display that I can always see the temperature now.
  14. Brian1954
    Brian1954 Senior Member
    2,686
    1,073
    South Central PA, USA
    I use a "P10" OBD2 display. It is small and not very expensive. Just search eBay or Amazon. User rjparker had a few posts stating that he used a P10 display. I looked at it and decided to buy one a year ago.
    There are many OBD2 displays that can monitor engine coolant temperature. Just search and find one that you like.
    Picture below: 20230227_151926.jpeg
    #34 Brian1954, Mar 6, 2023
