Engine Tune-up
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jerrycee11, Oct 4, 2012.
  1. jerrycee11
    jerrycee11 Junior Member
    PA
    Is there anything like an engine tune-up for a 2007 Prius? My car has about 68000 miles on it but just curious if and when a tune-up would be necessary.
    Thanks,
    Jerry
  2. Patrick Wong
    18,210
    6,515
    There really isn't much to a tuneup: at 120K miles, the iridium spark plugs should be replaced. Consider replacing the PCV valve then as well.
    The engine air filter should be replaced at 30K mile intervals and the engine/inverter coolant should be replaced at 100K miles; then at 50K mile intervals subsequently.
  3. jerrycee11
    PA
    Thank you - This is just what I was looking for.
    Jerry
  4. usnavystgc
    3,159
    990
    Tucson, AZ
    Yep, Prius mechanics are like the old Maytag repairman. There is not much to do.
