Engine tuneup and spark plug replacements
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Manura, Jun 21, 2017.
  1. Manura
    Manura Junior Member
    Galle
    2012 Aqua
    It's being while that I have posted in this forum, I have Toyota Aqua 62000km done. In our country there are rumors that Aqua or prius c need to replace spark plugs in 40000kms and need to do expensive engine tuneup at about same mileage. At the moment my car doesn't show any symptoms apart from slight decrease in fuel economy (maybe it's in my head). What's your opinion. Thanks in advance.
    52,649
    i don't have an opinion, but the u.s. manual has always stated 120,000 miles for plugs, and no one has had an issue before that. in fact, many are still in good condition when removed.
    other than oil and filter every 10k, cabin and air filter inspections, and tyre rotations, there isn't much to do.
    if you start to have issues at any point, some things to look at that aren't in the manual are throttle body/maf cleaning, pcv, egr, intake manifold and etc. but those should be way down the road, depending on the quality of your petrol.
    you may want to consider changing the tranny fluid at some point. all the best!(y)
  3. Manura
    Galle
    2012 Aqua
    Thanks, I have already changed transmission oil, but I also felt it's little too much.
  4. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    I'm at 66,000km and no worries so far. My fuel economy dropped pretty noticeably over the winter (more than the previous winter) and I started to suspect the plugs, but it recovered back to normal in the spring and I now put it down to the new front wheel snow tires I was running on over that period.
  5. zeuloa
    zeuloa Member
    30
    26
    Managua, Nicaragua
    2014 Prius c
    Here in Nicaragua manual for my Prius C says spark plugs at 100,000 km.
    iPhone ?
