Engine turning on and off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by amnyce, May 28, 2026.
  1. amnyce
    amnyce Junior Member
    28
    Pennsylvania
    At a full stop. My engine will shut on and off rapidly. No codes. No warning lights. Seems to correct itself when I start driving again. Any ideas !
  2. ChapmanF
    18,964
    How rapidly?
  3. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If your Prius is warmed up and the HV battery is fully charged, that is the expected behavior. The engine shuts down at a stoplight to save gas. It then starts back up when needed to provide acceleration. If you just accelerate slowly, the engine will stay off as the HV battery/electric motor can supply enough energy on their own.
    JeffD
  4. BiomedO1
    BiomedO1 Senior Member
    4,536
    2,388
    Left Coast
    I'm going to assume that you mean that the engine will turn itself OFF at a stop and then back ON again. How are you determining this? Are you looking at the power-flow diagrams on the MID or feeling the engine vibration and listening to the exhaust tones?
    If you have a weak or dying traction battery, that would probably happen. Next time this happens, look at how full the traction battery is. If it's at least a quarter full, the engine should stay off at a stop - otherwise the engine will fire to maintain a minimum charge level on that battery.
    Hope this helps.....
  5. ChapmanF
    18,964
    OP has never been back to say how rapidly....
