Engine Vibrating at certain ICE RPM
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Geschwindigkeit, Feb 7, 2026.
  1. Geschwindigkeit
    Geschwindigkeit New Member
    Glasgow
    I have this strange issue where if I'm driving at roughly 44-60 km/h and my blue bar in Hybrid System Indicator is three quarters full (halfway past the eco line, halfway to PWR), my engine vibrates + my whole cabin. It's completely fine at any other speed or acceleration.
    Here is a video where I get my engine to exhibit this behavior a few times roughly the first few seconds in. It's been getting louder recently.
    I've replaced my spark plugs and this issue still persists. I don't think it's the head gasket as my coolant is fine and I have no other symptoms for that issue. I have not cleaned my EGR yet.
    Other than this issue, my car runs fine.
    52,787
    How many miles on her? Maybe engine mounts
  3. Geschwindigkeit
    Glasgow
    119K I was thinking maybe engine mounts, too. I can try and check if my engine moves or anything.
    52,787
    have you ever cleaned the egr circuit?
  5. Geschwindigkeit
    Glasgow
    No, but I'm dreading doing it after reading the articles here. It sounds like so much work that I don't have time for. Can't I just take it out, take it apart, spray it off, and be done?
  6. bisco
    52,787
    Idk. I traded mine in to avoid doing it.
    Here’s a good video:
  7. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    With that symptom, I'd suspect the EGR ports of the intake manifold may need cleaning out. That's much easier than cleaning the EGR cooler (heat exchanger). Unequal clogging of those ports can cause rough running under moderate load.
  8. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,784
    Bay Area
    is your tires balanced? If the whole vehicle is vibrating at high speeds, uneven balance on the wheels could cause the steering wheels to vibrate at high speeds but not when driving at city speed.
  9. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    44-60 km/hr aren't particularly high speeds. If the vibration were caused by wheel imbalance, it wouldn't be sensitive to what the Hybrid System Indicator display shows.
    Brian1954 likes this.
  10. NutzAboutBolts
    1,756
    1,784
    Bay Area
    yeah I just converted to mph which is 27mph, which isn’t too fast :ROFLMAO:. Any check engine light?
  11. Geschwindigkeit
    Glasgow
    No light. I also noticed that it seems to only happen when the engine is cold. Could be wrong on that, though. I haven't tested it, thoroughly.
  12. NutzAboutBolts
    1,756
    1,784
    Bay Area
    put it on maintenance mode and rev the engine while its stationary and see if the vibrations still exist or not. If not, then it’s not your engine.
  13. Geschwindigkeit
    Glasgow
    With E brake on and in neutral? Or parking brake on?
  14. NutzAboutBolts
    1,756
    1,784
    Bay Area
    No need e brake. It’s in park so you just step on the gas pedal to rev the engine to different rpm to see if it mimics the vibration from the engine or not. If you don’t feel any vibration, it could be other issues.
  15. Geschwindigkeit
    Glasgow
    Seems like it's not doing it in maintenance mode.
  16. NutzAboutBolts
    1,756
    1,784
    Bay Area
    Does your steering wheel vibrate or it’s the whole car?
  17. Geschwindigkeit
    Glasgow
    Kind of the whole car. It feels and sounds like if the bass and volume of a stereo was turned up really high.
  18. Geschwindigkeit
    Glasgow
    I'm starting to think, that it's whatever is responsible for charging the high voltage battery that's the issue. If it doesn't happen in maintenance mode. The engine ran fine in maintenance, it might be whenever it's charging that this happens.
  19. NutzAboutBolts
    1,756
    1,784
    Bay Area
    what’s the history of the car and what’s been done to it recently? When did you start noticing it started vibrating?
  20. Geschwindigkeit
    Glasgow
    It's been pretty well taken care of. I changed the spark plugs a couple weeks ago and the 12V a week before that. I started noticing the noise last month.
