Engine Vibration/misfire possible reasons
Discussion in 'Gen 3 Prius Technical Discussion' started by Terror404, May 30, 2017.
  1. Terror404
    Terror404 Junior Member
    46
    houston, texas
    Hello,
    I have terrible vibrations on my 2011 prius. The thing is so terrible that in some moments I feel like whole car is falling apart.Vibrations only take place when electric power is not enough and ICE kicks in and you just try to maintain the rpm-s, as far as you floor it or just release the throttle vibrations disappear.
    First, I though it was all engine mounts' fault, I checked and re-tightended them all y'day. vibrations still persisted.Then I put my car on diagnostics.also had no check engine light. What I found was misfire on cyl 1. I changed all spark plugs today and while I was down to it switched 1 and 2nd coils for plugs. when I rechecked the diagnostics, misfire was still there on 1st cyl,so it means issue is still in 1st cyl, despite plugs being new and coils changed. Tomorrow I am going to check compression on all 4 cyl-s and see if there is a mechanical problem with the 1st one, by that time is there anything I can check? I was thinking of fuel nozzles, but want to check compression first.
    Could you please tell me any other items I could check?
    Thanks in advance
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    How many miles on your 2011? Have you investigated the egr and intake systems?
  3. Terror404
    46
    houston, texas
    107 miles. The intake is brand new, as the previous one was cracked after accident. I checked trouble codes on TIS techsream and it did not show EGR malfunction,I did not check it manually though
  4. Terror404
    46
    houston, texas
    little update.Although when I bought new (read "second hand") intake, it did look clean, I dismantled it as suggested and thoroughly cleaned the whole system, starting from EGR pipe and ending up to intake valves.Second reason I also was not lazy going that far is that I suspected that small piece of older intake fell between intake valve and its seat and wanted to check if there was any issue with that.if you have not stripped intake before I should mention that you can clearly see intake valves, even without boroscope which I kept in handy :) Long word short, I cleaned intake first with jet stream of water and afterwards by gunk remover spray,although it looked clean, there was lots of tar inside, especially on EGR line and as 1st cylinder is the furthermost its EGR line was the dirtiest and clogged.Afterwards I reassembled everything and car had no vibrations ever since, even with old spark plugs on (later I reinstalled the new ones).
    hope my experience will be helpful for some users here.
    P.S. Sorry could not take pix, as I was too dirty
    Aaron Vitolins and Raytheeagle like this.
  5. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Glad it worked out for you. At some point you should consider the egr valve and cooler, but that's for a later time.
    Enjoy your weekend (y)
    Terror404 likes this.
  6. Terror404
    46
    houston, texas
    Thanks for the help,man!
    Raytheeagle likes this.
