engine water pump failed to seal?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Chris77*, Mar 17, 2026.
  1. Tombukt2
    Tombukt2 Senior Member
    13,860
    2,519
    Durham NC
    You just keep filling the radiator an ounce at a time top of neck it gurgles down add another 45 min later water will stand at top of neck 5 full minutes without moving a bit . When it does that cap the radiator make sure the jug is full and you ready to ride . Heat on full tilt. You should have heat within 3 minutes and turning down of warm. Out . 10 min later back on park lot . Touch hoses top and bottom should be near same temps etc just still at same level as 10 min ago .
  2. Chris77*
    Chris77* Member
    103
    I think its burped out. I think i should leave the plug alone. I just topped off a tinny bit that it sucked down last night after it cooled off. This job is complete. Even with leprechauns.
  3. Mendel Leisk
    42,345
    Just thought I'd check that. FWIW, one of the bolts is 11 lb-ft.
  4. pasadena_commut
    pasadena_commut Senior Member
    3,065
    951
    Southern California
    For the OP. Go on youtube and look up "eyeonaiman". The kid has two very nice videos about filling and burping the coolant system. Here is one of them:
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,101
    6,966
    Texas Hill Country
    A vacuum fill system is relatively easy and reliable.
  6. Chris77*
    Chris77* Member
    103
    This video I watched. The mistake is I picked up whatever funnel off the shelf. Mine had a triangle tip on it, it wont seal and instead of fluid going up the funnel like video it dumps down the side. To be honest I am surprised the round one will seal. Otherwise you need a spill proof funnel or maybe dont use a funnel at all like Tombukt suggested. The spill proof would have been worth the extra in my opinion it takes 20 min so its nice to easily see the bubbles coming out. I know it sounds crazy content creator never emphasized the importance of using the correct funnel.
    IDK what else to say about it other than I might need to get my glasses checked. I got tired and I wasn't able to process this when it happened. I guess if you don't have a funnel in mind this will keep you from having to run back and forth to the auto parts when you have your car open.
    #26 Chris77*, Mar 19, 2026
  7. pasadena_commut
    3,065
    951
    Southern California
    Use a Lisle "no spill" funnel or a knockoff of it. Harbor Freight sells one, that is what I used. It clamps onto the radiator filler neck so that no fluid can go out the side. Since filler necks come in various sizes these funnels come with an assortment of "caps" and one will fit (unless maybe you have a very rare vehicle). Be careful attaching it on a Prius, the filler neck is kind of fragile - you want to support it while attaching the funnel.
    Here is the Harbor Freight part:
    https://www.harborfreight.com/no-spill-radiator-funnel-kit-58423.html
    and here is the Lisle part, which oddly costs less than the HF one today:
    (Amazon links don't work, go there and enter: B00A6AS6LY)
    Hmm, I see that some of the knockoffs now use a petcock (valve) below the funnel. That would be more convenient than the "plug on a stick" of the original design. Although it might be hard to get all the coolant cleaned out of it, which could result in a little mixing if the same funnel is used on different types of cars. Not recommending it, but for instance, see this Amazon listing: B09XT1XC55.
  8. rjparker
    11,101
    6,966
    Texas Hill Country
    It is possible to fill a cooling system with a funnel that does not seal at the inlet. Patience.
    Many "content creators" assume techniques used for 75 years with tools readily available at the auto supply are obvious. Regardless content creators are typically not trained in content or in instruction. Kind of the Ai paradigm once again.
    Having proper lighting is a plus.
    Avoiding the trap of confirmation bias is a hard learned lesson for some.
    You should look into vacuum filling - a technique not as well known by shade tree mechanics but easy, affordable and the method real shops use on complex cooling systems like gen2.
    #28 rjparker, Mar 20, 2026
  9. Mendel Leisk
    42,345
    FWIW, repair manual instruction attached. Pretty sure it involves Techstream.
  10. rjparker
    11,101
    6,966
    Texas Hill Country
    Vacuum filling a coolant system is not hard or expensive
    Car Care Nut got the memo
    #30 rjparker, Mar 23, 2026
