Engine Water pump needs to be replaced??
Discussion in 'Gen 2 Prius Technical Discussion' started by PRwanting, May 25, 2013.
  1. 2007Prius422
    2007Prius422 Junior Member
    rockville
    Dealer charged me $225 for new battery. I assumed it is a Toyota battery (???). A week later, I looked and was surprised to see it is a Panasonic battery. While they changed the battery, they looked the car over and told me the engine (?) water pump is starting to leak. Will cost almost $600.00. I don't see any leaks underneath the car when I pull out. I don't drive much and have only 37,300 miles on my 2007 Touring Edition Prius. I'm in their system, so if I go to another dealer for a second opinion, they will tell me the same thing.
    Who can I go to that will be trustworthy for a second opinion?
    What is the life expectancy of this part?
    Did my low mileage accelerate this problem? (I believe this is why I needed a new battery. It kept dying on me.)
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Go over those posts in this thread by 3ProngPaul. Look for the pink residue around the pump shaft. As he says, this is a common upsell from dealers. If you are not loosing any noticeable fluid, then you are probably OK for a while. $600 is too high.
    That is a low mileage to have a problem with the pump. It is understandable to have a problem with the battery, as they age whether they are used or not. Six years and it is time. Keep a battery minder on your car, and it will do better.
  3. PRwanting
    PRwanting Junior Member
    48
    Boston, MA
    So I took it to Meineke for second opinion. There's no leakage, only noise according to their mechanic. So I took it back to the dealer and asked the guy what he was talking about. He said the water pump needs to be replaced due to "excessive noise" and the baring inside the pump is getting old with age. So should I replace it?
  4. Patrick Wong
    18,210
    6,517
    1. Does the noise bother you?
    2. Is the pump bearing leaking fluid?
    If your answer is no to both questions, then leave the pump as-is until you can answer yes to either question.
  5. PRwanting
    48
    Boston, MA
    The noise isn't bothering me and it isn't leaking fluid, BUT my only question is what's the possibility that the pump may go bad. I'll be doing a lot of highway driving this summer. If the pump dies in the middle of the highway then I'm screwed.
  6. Patrick Wong
    18,210
    6,517
    One thing nice about a mechanical coolant pump like the Prius engine coolant pump is that you will get plenty of warning before the pump fails because the bearing will start to weep fluid. Just check the pump pulley interior once in a while for pinkish residue. If you don't see any and you don't hear any unusual noises, don't worry.
    Another issue that will cause a catastrophic cooling system failure is if the serpentine drive belt fails. You should change that at 75K miles or so, then you don't have to worry about the belt snapping while you are in the middle of nowhere.
    dave77 likes this.
  7. PRwanting
    48
    Boston, MA
    Thanks a lot. Appreciate all the help that I've got on the forum.
  8. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    The dealer should have another Gen2 Prius in their shop. Tell them to point out the noise your car makes, then walk over to another Prius and listen for the (lack of) noise. If you can noticeably hear the difference get them to change it.
    If they unwilling to demonstrate this to you, they are most likely scamming you. Time to find another dealer.
    A noisy bearing will likely implode, but it could last another 2 weeks or 2 years. It will be get louder before it fails catastrophically. Luckily any shop that works on normal Toyotas can change Prius ICE water pump. If you have AAA towing you may want to just buy the pump and gasket and carry it around with you if you go on a trip. They are not very expensive.
    Catonsville Bill and dave77 like this.
