Engine will not turn over after replacing the engine
Discussion in 'Gen 2 Prius Technical Discussion' started by Chris Carter, Nov 9, 2019.
  1. Chris Carter
    Chris Carter Junior Member
    Arizona
    So we have replaced the engine in my 2004 Prius. It sat for about 3 weeks. The gas engine does not turn over and doesn’t give any error codes. Any suggestions are appreciated. Thanks
  2. ydpplqbd
    ydpplqbd Active Member
    551
    254
    Did you try turning the motor over before you installed it?
    audiodave likes this.
  3. Aegean
    Aegean Active Member
    464
    209
    Alexandria VA
    Take out the spark plugs and belt. Turn it by the crankshaft bolt with a wrench. Does it turn?
    52,915
    more details?
    ready?
    drive?
    ev?
    or is it just dead, and you didn't replace the orange safety switch properly, with all 3 steps
