Engine wiring harness safety recall (model year 2016–2018)
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by JosephG, Sep 5, 2018.
Tags:
  1. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    randomwalk is a good man from Texas. Depending on which part of Texas he's in, there can be lots of blowing wind / dust / dirt.
    So where exactly are those wires that might fray? Are they inside that black box in my photo? Behind the box? Underneath or on top of the box? With all those earthquakes they have in Japan, I wonder if the workers can keep their mind on their jobs. Can't blame them if they make a mistake occasionally.
  2. altdel
    altdel Member
    70
    36
    Danville, CA
    Looked up my 2016 Prius 2 and the result was: POSITIVE. This is the third recall for my vehicle.
    51,925
    the first 3 of many...
    altdel likes this.
  4. alexgrigori
    alexgrigori Active Member
    163
    109
    Technology
    My VIN search returns: Customer Pre-notification
    SRC R63 (Interim Réf. X63) – Certain 2016-2018MY Prius Engine Wire Harness
    What does it mean?
  5. altdel
    altdel Member
    70
    36
    Danville, CA
    Is that the Canadian version of the US Recall I got when I looked mine up:
    Safety Recall J0T (Interim J1T) - Interim Notice Certain 2016 - 2018 Model Year Prius Engine Wire Harness
  6. Fester
    Fester Active Member
    201
    198
    Ohio
    Had a look at mine today. As Randomwalk said, the right connectors cable does not go near the cable cover. The lefts connectors cable however does come in contact with the cover. Depending on how long Takes to do the recall, a few turns of abrasion resistant tape on the left one would be the fix I'd employ.
  7. alexgrigori
    163
    109
    Technology
    my VIN is registered with Toyota Canada and it is the place to check for recall.
    I don/t understand what Customer Pre-notification status means.
  8. alexgrigori
    163
    109
    Technology
    Just got an explanation:
    The purpose of this pre-notification is to provide you with important information about this recall.
    What is the defect?
    The subject vehicles have an engine wire harness which is connected to the hybrid vehicle Power Control Unit. The wire harness has a cover attached at this connection. Due to assembly variation, a portion of the wire harness could contact the cover. If dust has accumulated on the wire harness or the cover, vibration during vehicle use may cause the insulation on the wires to wear over time and expose the core wire, causing an electrical short circuit to occur between the damaged wires and generate heat. If sufficient heat is generated, there is an increased risk of a vehicle fire.
    What will Toyota do?
    Toyota is currently preparing the remedy for this campaign. Once preparations are complete, Toyota will send an owner notification letter by first class mail to owners of vehicles covered by this recall.
    What should I do?
    Once you receive your owner notification letter, return your vehicle to a Toyota dealer. The dealer will perform a repair at no charge to you.
    HPrimeAdvanced likes this.
  9. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    What I read into it is "currently preparing the remedy" - likely means they have spotted a potential problem, which they said "if dust has accumulated" and "wear over time" - but they haven't finalised the solution.
    Suspect just warning owners to be prepared for a coming recall. Which TOYOTA Australia hasn't done yet.
  10. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    ...if there is "dust accumulated" then I guess mine will be affected. LOL...
  11. alanclarkeau
    7,045
    7,592
    I've only got (besides what I just vacuumed inside the house) dust which accumulates on the Piano Black entertainment system and surrounds. Oh, for an all white interior ...
  12. mark27lim
    mark27lim Active Member
    108
    104
    singapore
    Many thanks to the MANY kind souls who posted helpful info about the recall. From my car examination it looks like both the left and right wire harnesses are pressing onto the top cover edge which itself feels quite sharp. i took photos of the right wire which seems to show some wear in my case, revealed by my finger pressing down on the pressure. My initial thoughts are to either remove the cover or cutaway a notch to relieve the pressure. but i’ll wait and see for now.
    unfortunately to meet my budget i didn’t buy from an authorized dealer. others may dream of a lambo or i8, i’m driving mine already
    UltraJetRefill likes this.
  13. alanclarkeau
    7,045
    7,592
    No matter where you bought the vehicle, TOYOTA will fix it for FREE. I had a car (Daihatsu) and was at least the 3rd owner, but Daihatsu contacted me and it was done free. [and no, I don't want a Lambo or I8 either]
  14. randomwalk101
    532
    271
    texas
    Can you take another picture zoom out & may be point to the exact area to get a better perspective of exact where that is??? Thanks
    tomcornell, kithmo and UltraJetRefill like this.
  15. Melton
    Melton Junior Member
    Looks like both of the wiring harnesses are touching that top cover on my '16 and it appears that both of them have dug into the electrical tape which is covering them and there is clearly an indentation on the plastic cover above it.. Wondering how they will fix it..
  16. mark27lim
    108
    104
    singapore
  17. alanclarkeau
    7,045
    7,592
    The RECALL has now appeared on TOYOTA AUSTRALIA's website as a press release. It seems that all Australian PRIUS Gen 4 are affected - mine is in the VIN range.
    One detail they've advised:
    Q6: How long will the repair take?
    A6: To inspect the engine wire harness and add protection material will take approximately 30 minutes.
    Should engine wire harness damage be identified during inspection, the wire harness will be replaced, which will take approximately four to five hours.
    However, it may be necessary for the owner to make the vehicle available for a longer period of time depending upon the dealer's schedule.
    [ Press Release - TOYOTA AUSTRALIA TO RECALL VEHICLES DUE TO POTENTIAL ENGINE WIRE HARNESS MALFUNCTION ]
    #37 alanclarkeau, Sep 7, 2018
    HPrimeAdvanced and mark27lim like this.
  18. UltraJetRefill
    156
    93
    Tucson, AZ
    I always get nervous hearing about 'wiring harness' replacements. Is this wiring harness contained in the engine compartment, or does it travel through the firewall into the passenger cabin? It would be a shame to have to have the dashboard area all yanked apart for this fix.
  19. alanclarkeau
    7,045
    7,592
    " four to five hours" - not sure they'll dismantle a dashboard in that time - and reassemble it? It was listed as a 12 hr job on my VOLVO to replace the heater/A/C Motor, and that was pre-computer.
  20. UltraJetRefill
    156
    93
    Tucson, AZ
    I'm just jaded after having the Takata airbag replaced on a Subaru Forester awhile ago. The dashboard squeaked/rattled after that. I'm probably just being 'tinfoil hat-like' about the whole thing. :D
    Tyfly and alanclarkeau like this.
