Engine wont start on my Prius 2001.
Discussion in 'Generation 1 Prius Discussion' started by Brandon Doyle, Feb 21, 2016.
  1. Brandon Doyle
    Brandon Doyle New Member
    New York, NY
    2001 Prius
    Hello everyone.
    So right now I'm not able to start my Toyota's engine. I checked multiple screens and found several weird symptoms that I never saw before.
    1. When attempting to turn the engine on, the square light that appear over the selected D, N, P positions etc does not appear at all and the 'Ready' light never appears. When putting the car into the Parked mode the square does not appear over the 'P' on the dashboard or any of the other modes and Ready light does not display.
    2 . On the dashboard the fuel gauge is blinking continuously. Its showing full bars while blinking even though I have about 3 cars worth of gas in the car.
    3. On the computer screen when I go to the Energy menu (The screen that shows the Battery life and the Motor and Engine working together) The battery life is showing as completely empty. But the battery should be working considering the computer screen even turns on. Radio also works.
    4. The OBD II scanner does not get a reading. The scanner powers on when plugged into the car, but a "Linking Error" occurs when attempting to read any error codes.
    5. On the same computer screen where the Energy menu is displayed, the Temperature gauge is showing an "E" instead of an actual temperature.
    6. On the outside of the car I hear a very faint sound that I don't recognize. It could be nothing but its not a sound I ever heard before.
    Also NO WARNING LIGHTS are appearing on the dashboard. Which makes sense considering the car engine is not turned on to show anything.
    Any help will be greatly apprciated I don't know where this issue is coming from. Thank you so much.
  2. Brandon Doyle
    New York, NY
    2001 Prius
    Im checking that now. I'll keep you posted. With all the symptoms listed would this be the battery in the trunk for the radio is still able to turn on and the screens are on?
  3. Brandon Doyle
    New York, NY
    2001 Prius
    Removed battery and tried differento working battery. 12v Battery is not the issue.
  4. DRACO
    DRACO Member
    362
    78
    Rancho Palos Verdes, California
    2002 Prius
    OP, S Keith asked what is the voltage of the 12v battery. If the other and the old one is under 12.5v that will cause havoc with our cars.
  5. Brandon Doyle
    New York, NY
    2001 Prius
    Hi Draco and Keith, I found out what the issue was. Turns out one of the fuses inside the fuse box under the hood was blown. We replaced the fuse with a brand new fuse and all the above issues were fixed! Its the size of a fingernail and literally caused all the above issues to appear. Amazing..
    Thank you for the assistance I greatly appreciated the tips!
    usnavystgc and bwilson4web like this.
  6. dolj
    dolj Senior Member
    8,646
    4,398
    Wellington, New Zealand
    Replacing a fuse isn't, in and of itself, a "fix". You really need to find out what was the underlying cause of the fuse blowing in the first place.
    What fuse did you replace?
    Alfonso13 likes this.
  7. DRACO
    DRACO Member
    362
    78
    2002 Prius
    All's Well that Ends Well :)
    Good for you :)
  8. Alfonso13
    Alfonso13 Junior Member
    South Florida USA
    2003 Prius
    Most likely he replaced a 15 amp blue fuse labeled "AM2" just below the bigger black horn relay by the driver's side under the hood.
    pshawfocus and Woody3 like this.
  9. Woody3
    Woody3 Junior Member
    2002 Prius
    I
    That is the fuse it was for me. Gen 1 250,000 miles. HV battery is still going. I have replaced 4 cells in the past 5 years. All at the same time. Most of the cells are original. Thanks for the tip on the fuse.
  10. mhutch1205
    mhutch1205 New Member
    Austin
    2003 Prius
    I
    I am having the exact same issues as original post, in addition to "electrical smell".
    Which fuse is it? (I had my Prius towed, so I do not have it in front of me to check)
  11. Naenoa
    Naenoa New Member
    Hawaii
    2003 Prius
    I
    You folks are terrific. Saved me thousands of dollars. It exactly was the AM2 fuse that blew. Thank you!!
    mroberds likes this.
  12. Naenoa
    Naenoa New Member
    Hawaii
    2003 Prius
    I
    11/2/18 Update. The reason the fuse was blowing was because the inverter coolant pump went bad. The official Toyota part is G9020-47022. I bought it through Amazon Prime for about $150 and watched YouTube on how to change it. It’s not that difficult but not too simple either. A tell tale sign for me that the pump was going bad was the AC air was not blowing cool air whenever I was at a stop light. After about 2 weeks, the engine just died while I was driving. Hope this post helps others.
    pshawfocus likes this.
