Enginer 4Kw PHEV DIY install
Discussion in 'Prius PHEV Plug-In Modifications' started by NortTexSalv04Prius, Feb 11, 2012.
  1. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    you can use aftermarket BMS along with enginer BMS. I used MiniBMS for charging discharging, and balancing and the Enginer BMS for displaying battery and converter status.
  2. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    116
    What is the most recent (currently selling) "enginer" "battery pack" image apperance.? I assume by the "website" they are the "real force" lifepo4 pouch inside a ss box with anderson connector because website images are ss box "pouch" and yellow "prismatic" data sheet.
  3. Gun owning Prius driver
    397
    78
    Downey, California (Los Angeles Area)
    So what your saying is you showed thag chick at the gas station your unit? Lol
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Version 6 does use Realforce cells in ss box.
  5. NortTexSalv04Prius
    915
    116
    Hey
    I am gettting some used packs ....can the pack be removed from the ss container ? do you know ericb
  6. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    Yes, they can be carefully removed.
    Often it is a frustrating process, though.
    And certain cells will generally only fit/reach their original locations.
    dave77 and NortTexSalv04Prius like this.
  7. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    Need to be carefull not to rip the cell tabs. Sometimes the case screws have to be drilled out.
  8. NortTexSalv04Prius
    915
    116
    yea I already found what that will not turn.............
  9. NortTexSalv04Prius
    915
    116
    Hey EB aka ericbecky hope you do mind that title.? Are you going to be a installer/dealer for whatever group replaces Enginer/Fountainhead electr/realforce/aka the other PC poster (sushi)?? Also I notice Realforce has some dealer in states(Oregon) aka powin energy that shows prismatic realforce lifepo4 but have to email the sales........
  10. lopezjm2001
    1,146
    407
    Sydney Australia
    Looking at this link. It may be possible to replace all the RFE cells with Headway cells.
    Lithium Ion Battery pack LiFePO4, 24v 80Ah - Plug-in Autos
    They claim to fit 64 Headway cells 38120L 10AH into a metal box 382mm x 248mm x 147mm.
    You would need to insulate all the inside of the box with electrical insulation paper. Use thread-lock Loctite for the cell screw electrical connections so they cannot vibrate out over time. And use foam sheets as a filler for a snug fit
    dave77 likes this.
  11. dan2l
    dan2l 2014 Prius v wagon
    653
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Tex,
    No, Powin is not an installer.
    I have been to their site. They are the import warhouse that got stuck with the extra Enginer inventory of systems because Enginer owed them money. You know more about the Enginer system than Powin knows.
    Currently they are willing to sell the systems with no warranty or any garentee, and that at a price that is higher than the systems are worth. Also they will sell you replacement pouches that are not designed to fit in the battery box.
    Thanks,
    Dan Lander
  12. Greg Wilson
    Greg Wilson Junior Member
    Elon, North Carolina
    Is the place in Winston still in business? As you know Enginer went out of business and the place that did my install is non-viable at this point. I need someone to honor my warranty--I still have another year and I have a charging issue right now. You had much much better luck that I've had and it sounds like your installer was a big reason (they may have known how to work around the problems with the kit). The guys that did my install tried but in all fairness, it was their first install on the Enginer line. I'll search Greencycle but if you have any info, please let me know. My email is [email protected]. Thanks.
    in
  13. NortTexSalv04Prius
    915
    116
    Already was aware about domestic USA installer ....
    However can this "import warehouse" sell to PC people???????????
  14. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    NorTex,
    Yes, Powin can sell the remaining stock of Enginer systems to people, but it is more expensive than Enginer ever sold them for, plus there is no warranty or guarantee.
    Greg Wilson,
    No one will honor the Enginer warranties in the US.
  15. NortTexSalv04Prius
    915
    116
    thanks eb
  16. donalmilligan089
    239
    22
    virginia usa
  17. donalmilligan089
    239
    22
    virginia usa
    I am on my second year with version 6 enginer. Recent m57.5 mpg to 69 mpg over the same terrain for past 6 wks. I installed hankookn tires on front and otherwise did nothing.milliage has in creased to 69 mpg over last 3 fillups I HAD A LITTLE TROUBE TO START BUT now going smoothly.I often get trouble codes but easily clear with scan guage The codes often appear after sitting in hot sun for hours If soc gettsv too high codes appear but that is my fault.Could hankook tires make the difference in mpg?
    dave77 likes this.
  18. Greg Wilson
    No one ever honored my warranty and after 1 bad cell replacement at my expense, I'm now looking at 3 more bad cells. Jack's a nice guy but Enginer should be avoided as should any company that refuses to stand behind their product and warranty.
    I can't even find the replacement cells to fix my kit. I'm told that the worthless bms is the issue--I've found a replacement bms but no cells.
  19. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    Jack's Enginer company has not been in business for a few years.
    A different company is using the Enginer name.
    You have lots of cell choices, but they will not fit in the existing form factor.
    Basically you have an orphaned product. No support. No warranty.
    Feel free to call me to discuss options.
