Enginer 8kw Phev
Discussion in 'Prius PHEV Plug-In Modifications' started by NortTexSalv04Prius, Feb 6, 2012.
  1. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    116
    Has anyone DIY a Enginer 8Kw:confused:
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Yes, I have done several 8kw kits in Prii with older versions on the Enginer kit./
  3. NortTexSalv04Prius
    915
    116
    Okay, with that additional weight did you update the suspension? What year was the last install you did?
  4. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    I have done a gen 2 and a gen 3.
    It is not required that you do a suspension upgrade, but sometimes people prefer it.
    Especially if you regularly have passengers, as opposed to doing mostly 1-person commuting.
  5. NortTexSalv04Prius
    915
    116
    Thanks
    If I took my 07Prius and did a Enginer 4kw install okay. Then did a lowering coil spring replacement would that be okay?
  6. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    I have done a 8KWH install on my Gen2 Prius. You do not need spring replacement but the rear wheel arches are a lot lower and very noticeble. Some say that it will not handle as well when driving because of uneven weight distribution. After all it is not a performance car. But if you have your springs lowered you may experience times when the rear wheels hit the arch specially when going over speed humps. The extra weight lower the rear arches so they come closer to the top of tyres.
  7. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    What you are talking about would seem to indicate a need for customized springs. Or at least a shop that has the knowledge to fit a spring to your very unique situation: Adding extra weight and lowering a vehicle.
    Explain to the shop exactly what you are doing ahead of time (extra weight, placement, etc) or go to them after you have the kit installed and they can do an assessment and give you a recommendation.
    2 people like this.
  8. NortTexSalv04Prius
    915
    116
    Well I have seen where some gen 2 forum members have done a eibach coil lower kit $250 parts only and that lowers the vehicle around 1" . So just curious with a extra 160lbs 4kw phev kit how vehicle would do??
  9. Flying White Dutchman
    4,376
    313
    use somthing like this
  10. chenyj
    chenyj Member
    96
    115
    Troy, Michigan
    Here are some of the pictures for our latest 8KWH kit.
  11. lopezjm2001
    1,146
    407
    Sydney Australia
    Are you meant to discard the cargo container and lid and side pockets. Can the cargo lid still go on top? Or should it be removed for maximum cooling.
  12. suprat04r
    suprat04r Junior Member
    85
    las vegas
    are any and all 8kw kits (enginer and plug in supply, etc) needing to stash the extra batteries above and in the cargo area?
    meaning, you cannot put all of it under the mat?
  13. NortTexSalv04Prius
    915
    116
    To start
    The cells on Enginer kits RFE store above and below cargo area depend on how some one configures .Enginer has 8kw and PIS has 10kw. On any PHEV you will gain weight and lose trunk,cargo, spare tire, and rear vehicle space.. if done correctly most will go under the rear floor mat.
  14. NortTexSalv04Prius
    915
    116
    Thanks
    I assume that the 2kw, 4kw, and 8kw Enginer is all that is currently offered unless you mod two or more kits.....per Enginer www site..
