Enginer Charger NTC inrush current limiter
Discussion in 'Prius PHEV Plug-In Modifications' started by pbui, Aug 6, 2014.
  1. pbui
    pbui Member
    190
    Los Gatos, northern CA
    I have a bad Enginer charger with burned NTC current limiter. I can't see the marking enough to order some replacement. Does anybody know the part number ? or if you have a charger lying around, please open it up and post the part#. The red wire goes directly to the AC input plug.
    Thanks
  2. mrbigh
    3,686
    699
    Long Island, NY
    contact ericbecky, he's the man................
    NortTexSalv04Prius likes this.
    52,004
    if he can't do it, no one can.:p
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,441
    3,332
    Madison, Wisconsin
    ok, ok... I'll go open up one and take a peek.
  5. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    Looks like I do not have an Enginer charger here similar to that one. Take a pics of the exterior of the charger. Top, ends, connectors.
  6. pbui
    pbui Member
    190
    It's from Enginer V6 kit. I am thinking of jut selecting an NTC capable of 12-15A. I think the problem may have been that there were two NTC in parallel, probably to share the total load. But of course both are not identical and at time one must have carried the full load and thus started to burn up.
  7. hkgngplugin
    hkgngplugin Junior Member
    46
    Hong Kong
    Why don’t you open up yours and show us what’s burnt?
  8. pbui
    pbui Member
    190
    here the picture again. The red wire is the AC wire from the AC plug.
  9. pbui
    pbui Member
    190
    sorry, am having problem inserting image, try again:
    #9 pbui, Aug 19, 2014
  10. pbui
    pbui Member
    190
    quick update: i purchased a couple of NTC from Newark Electronics, just picked one for 20A, 5%, <$2 each. I went ahead and put two in parallel as there were two originally, though at 20A each, I think it's over the top.
    Slap them in and the charger seems to work again, yeah ! even got the pack charged to green LED.
