Enginer kit proper break-in charging cycles
Discussion in 'Prius PHEV Plug-In Modifications' started by Hunter1, Aug 19, 2009.
  1. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    Thanks very much for the balancer PDF file. I will definitely try that this weekend. I put 4 cells in parallel with different voltages last night and this morning they were all the same voltage. As for the copper connectors, Jack is out. I think I will head over to hardware store and see if I can get a strip of copper to make my own. I am wondering if I should put all 64 of my cells in parallel for a few with a 2A load from a H11 light bulb and let them balance out before I make the 4 cell buddies? hmmmm
    Unfortunately my kits is down. I lost another cell last night and it is in the tire well. Will have to wait for this weekend to pull it out. Fortunately Jack is sending me 4 cells when I only had 3 cells bad last weekend. It seems like the cells are falling in a cascade. This makes 4 bad cells out of 64 so far.
    Thanks,
    Chan
  2. Fibb222
    Fibb222 New Member
    1,499
    99
    I have had to replace 4 mottcells so far. Haven't used my kit more than a day in the last month. Tonight, I'm getting it back online.
  3. boppo
    boppo Active Member
    799
    139
    Owego, NY
    will these kits ever be plug and play for normal folks?
  4. Fibb222
    Fibb222 New Member
    1,499
    99
    The kits may never be, but the oem PHEVs and EVs will probably be very maintenance free.
  5. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    I think when Jack iron out the testing process and installers are more available then yes it will be much more plug and play. I knew I was going to be part of the pioneering few when I got in and have not looked back.
    Chan
  6. ias513
    ias513 New Member
    Hershey, Pennsylvania
    2001 Prius
    Here's my 2 cents.
    I have been running a 2kw system since mid Aug on a Gen I Prius.
    I often run about a total 10 mile commute to work and back. I was plugging in every night. I am getting the feeling that maybe I should have only plugged in when my Enginer pack's cell voltages became a bit lower.
    Although I did not record it, I think I was often recharging when the cells were a bit on the higher end of their range. (I seem to remember often seeing 3.2 and 3.3 readings.)
    I have also been seeing the weak cell problem. When I get all my cells in good shape again from Jack, I'm going to try to charge them more on a milage basis that will not discharge them too deep, but at least allow them to discharged a bit more into their cycling range.
    I'm just winging a number here for now, but I'm thinking once I see a cell drop down to around 3.000 V or lower, then I'll recharge.
    I'm basing this on my kit and also helping a couple of other's with theirs.
    In general, I think the cells are very sensitive to overcharging.
    Anybody have an opinion on this?
  7. Fibb222
    Fibb222 New Member
    1,499
    99
    I think you might be on to something there. I was under the impression that the charger was smart and wouldn't overcharge. Unfortunately, it might not be the case. It appears we might need to get under 3.1V before we charge again, just to be safe.
    When I had a Li-ion electric bike kit, I was given the impression that it's better for the batteries that you charge them even if you only depleted them a little bit - that they liked to be topped up. That was lithium-manganese though and may have been bad advice to begin with.
    I once bought an mp3 player from a girl and she said she was very diligent about draining the lithium battery down to zero or near zero before she charged it up again.
    So who knows what to believe. What I really don't like it is the weak red led on the dash switch and that the only audible alarm is from the balancers buried under the carpet deck.
  8. Fibb222
    Fibb222 New Member
    1,499
    99
    Anybody see a mottcell with the red label between the terminals coming off and the white foamy bit protruding out from underneath the label? I've seen a couple of those. Jack told me to replace them.
  9. ias513
    ias513 New Member
    2001 Prius
    Yea,
    I saw a few of those last weekend. I thought it was just al oose label.
    Did not look close at the label area for foam.
    VERY INTERESTING...
  10. Fibb222
    Fibb222 New Member
    1,499
    99
    Best to ask Jack about them.
    Jack is very quick to support customers with new parts. I hope he can continue doing so.
  11. rickw
    rickw I get miles per KW
    Mchenry,Illinois
    2002 Prius
    I
    Hello
    I have the 4kw in a gen I prius charging batteries is a pain the problem is its a smart charger but it does not know the individual cell voltage but the total voltage of all cells combined. The balancer is suppose to keep the cell voltages equal. Thats why they start beeping near the end of charging to let you know a cell is over 3.7 volts above that is a bad thing for that cell. Ive been trying to improve the balance of charge by letting the batteries discharge until the red light comes on turn the unit off for 10 minutes let the balancer do its thing than turn the switch back on til the light comes on and repeat process. That way all cells end up equally discharged and should charge at a more even rate. I also am also using a timer to charge 2 minutes off 58 minutes to give the balancer time to equalize voltage. The first hour or 2 should be ok to constantly charge them. High cell voltage is going to shorten life of the battery.
    You want to keep the lowestcells above 2.8v and the highest below 3.7v
  12. donalmilligan089
    239
    22
    virginia usa
    I would like to know how concerned one needs to be when one reads of all the charging,balancing and all that goes with getting the enginer off to a proper start. There seems to be a lot of discussion about these things
  13. dan2l
    dan2l 2014 Prius v wagon
    653
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi donalmilligan089,
    Right now, I would say that the operator needs to stay within audile range of the balancers, 100% of the time, while charging. and then need to be sure to turnoff the charger if an allarm sounds. The rest of the discussion are important for knowing what is going on, but should not nessisarily need to be checked all the time. Having said this, I will remain vigalent for many charge cycles.
    This is a quick answer. I hope it is to your point.
    Thanks,
    Dan
  14. Fibb222
    Fibb222 New Member
    1,499
    99
    This is correct. The charger can easily overcharge the cells. I think 1.5 hours on a count down might be more manageable, if you don't mind not fully charging your kit.
    Also, let the cells balanced completely (d<0.010) after the kit is spent, before charging.
  15. minnesota_plugin!
    minnesota_plugin! New Member
    I just purchased a 6 KWH kit and am getting it installed next week. I am up north and its 0 degrees out now, and -10 at night and my garage is not attached, so a freezer with a car in it. I cannot stay out in the garage with my car for six hours every night, so i am buying a baby monitor so i can monitor my little baby balancers and tend to them when they cry, i mean beep:eek::eek::eek:
  16. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    146
    Fort Worth, TX
    I'm going to be installing the kit into a Gen-1 Prius in a week or two (whenever the darned thing arrives) But I just have to wonder if there isn't a better solution. For example, a way to allow the battery balancer to turn off the charger in the event of a cell nearing a state of overcharge? Or maybe using shunts on each cell instead?
  17. Daox
    Daox Member
    196
    58
    US, Wisconsin
    Unfortunately, unless you build something yourself, the kit is the way the kit is.
  18. minnesota_plugin!
    So, does my baby monitor idea sound like a solution? Does anyone else have any other ideas about how to monitor the balancers without freezing or even if it was summer, staying in my garage every night...Any other ideas anybody? Even if it involves buying a smaller charger or something....?
  19. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    minnesota_plugin!,
    I had the very same idea. I haven't implemented it, but it sounded cheap, fast, and would get the job done.
    There are a few other ideas floating out there, like
    - getting a less aggressive charger
    - putting it on a multi-increment timer (charge a while, rest a while)
    - using two sets of chargers, one for fast charging within your known safety zone and then switching to a trickle charger to top things off.
  20. dan2l
    653
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hello everyone,
    Fisrt we need to do Buddy Cells. This does the most to save cells from extremes in curent flow and high or low voltages.
    Second Enginer has turned down the Charger from 58v to57v. For my system this worked the first time with no allarms. I was close(90mv) but no allarm and the charger did shut down. I did get 2.5kwhr ito the batteries in 4 hours of charging.
    I caution against cycling the charger. When I turned my charger back on with fully charged batteries I got 13amps going into batteries that should have been only taking a trickle. I do not know how fast the charger will cut back in the second charging cycle.
    Next Jack is still working on a fix for this. Long term I think he is geting a 16 cell balancer with higher curent flows to be quicker at balancing. He knows that he needs to have this balancer shut down the charger. He is also woeking on a short term fix but I am not sure what that is.
    In the mean time, The DB8 balancers we have now do have charger shutdown cappability. It is limited to 36v10a. So this will not work with todays charger. I plan to work on replacing the charger I have now with a pair of 30v10a chargers. I have not purchased parts yet, but I think powersupplies like this should be easy to get.
    This is a wireing diagram that I think will work to have the Balancer stop the charging using 2 smaller chargers. Note that it does have Buddy cells.
    I will get to this at some time in the future. But if one of you gets a chance to make this work sooner Please let us know how it goes.
    Thanks,
    Dan
