Enginer PHEV Test Pilots: Mpg reports and important data
Discussion in 'Prius PHEV Plug-In Modifications' started by plugmein2, Aug 17, 2009.
  1. eMileage
    eMileage Member
    33
    38
    Toronto, Ontario, Canada
    Initial impressions with the Enginer 4KWh system have been EXCELLENT! This is exactly what I've been planning since well before getting my Prius in 2006. This system delivers the extra charge that I've been needing to extend my driving efficency under many conditions. It also feels great to be driving on Solar power! :) Monitoring various parameters using ScanguageII (most often SoC, BTA, RPM & LHK) has helped me to make the most of the extra available energy.
    For those who do not have a scanguage or prefer to use only the Prius MFD while driving, the following chart might help you to maximize use of stored charge in your Enginer PHEV system and perhaps further increase your efficiency. This is certainly not a replacement for a scanguage since this will only give you an idea of the SoC, and only at the times when the battery bar graph changes. Note that the transition points on the bar graph are different when charging and discharging the Prius OEM traction battery.
    For example, when decelerating/regenerating or at a stand-still and current is flowing into the traction battery, the appearance of the 7th bar (1st green bar) on the MFD means the SoC is approximately 66.5%. However, when accellerating or in EV mode where current is being drawn out of the traction battery, and the 8th bar just dissappears (ie. also at a 7bar display), the SoC is approximately 73%. Unfortunately, this does not apparently mean that the 7th bar represents a SoC in the range between 66.5 and 73% because as discharge continues to the point when the 7th bar just disappears, SoC is reported to be approximately 64%.
    The current being delivered to the HV bus from the Enginer system varies dynamically but while stationary, current flow into the OEM pack often seems to hover between -7 to -9.5A. This typically means that the traction battery gains 0.5 SoC approximately every 10-15 seconds (A/C off, heat off, fan set to second level--Lo+1). Of course deceleration regen can deliver a much higher current depending on many factors, (including speed, rate of decel/braking rate, battery temperature, etc) and related parameters (including Charge-Current-Limit (CCL) and Discharge-Current-Limit (DCL)). For example, if the battery temperature is below ~32deg C regen current appears to be limited to the -45A range. But a warmer battery (perhaps over ~36deg C) might see currents as high as over -90A during regen.
    The Prius likes to keep the traction battery near 60% SoC. So if SoC is higher, it makes greater use of this stored energy. If SoC is too high it will try to drain power from the battery. And if SoC is too low (<45% SoC) it will start the gas engine to help recharge the battery. Observations seem to indicate that maintaing a SoC in the 65-75% range produces some very efficient results with mainly gentle city driving (currently averaging ~2.1LHK (~112MPG), ~5% highway, ~25km/h avg, temperatures ranging from 15-26deg C (~60-78F)). A full charge appears to last for about 45KM/28 miles of driving. Of course, results will vary with traffic/driving/road conditions, driving style and climate.
    One last pointer -- even when in EV mode, letting off the accelerator and gently re-applying, after attaining cruising speed can often reduce current draw from the battery and perhaps extend EV range.
    Please feel free to share other observations and experiences even if they differ from what is described above. I am very pleased with the results from my 4KWh Enginer system thus far!
    Cheers!
    7 people like this.
  2. chenyj
    chenyj Member
    96
    115
    Troy, Michigan
    Although the charger and the converter are isolated and it won't damage the system with both on, it is not recommended to do so since the smart charger is not smart enough to know why the battery voltage fluctuates (because of discharging at the same time) and won't work correctly.
    4 people like this.
  3. Fibb222
    Fibb222 New Member
    1,499
    99
    As I said in the other thread my first test drive on Wednesday (1 day after my install) I drove around almost exclusively with electric only for about 25 minutes and scored a series of 2.5 L/100km bars on the MFD. Nearly the whole time, the OEM SOC was 5 or 6 bars. I accelerated hard with the ICE and maintain my speed in long cruises on electric only. (after accelerating, I let my foot off the gas and put it back down lightly to fire up the electric motor only).
    I don't think I came anywhere near to emptying the pack. 4kWh is a lot apparently when driving in the manner described above. Not sure what I would do with 8kWh.
    I've checked my voltages a few times before and after charging and found them to range from 3.30 (partially depleted) to 3.37 (fully charged). The batteries were also balanced pretty well right out of the factory.
    I'm curious to find out what the voltages are when the pack is drained enough that the red light comes on on the dash switch.
    Tonight and tomorrow I'll be doing some serious driving around so I'll have a lot more data.
    Once concern I have is the smell. 3 of my batteries were a little scorched looking near the terminals. My kit is a bit smelly perhaps from that or perhaps from the newness of the electronic bits in the converter/charger getting warm for the first time.
    Also after I unplugged the charger, the red/green lights flashed on/off about 3 times and it clicked each time. I don't know if this is normal or not.
    2 people like this.
  4. drees
    drees Senior Member
    1,782
    247
    Better make sure all the terminals are tight.
    There shouldn't be any scorching going on.
    2 people like this.
  5. Fibb222
    Fibb222 New Member
    1,499
    99
    The scorching was evident before we unpacked the batteries. Must have happened at the factory/warehouse in China.
    The terminals were all fastened tightly during the install.
    I bought a temperature gun on ebay today so I can make sure there aren't any hotspots.
    It'll take a least a week unfortunately.
    2 people like this.
  6. Fibb222
    Fibb222 New Member
    1,499
    99
    Tonight I drove quite a ways (54 km) to run a couple errands and again averaged around 2.5 L/100 km (~112 mpg) Still didn't drain the pack.
    And this time the OEM SOC was often 7 bars full.
    WHOO! HOOO!
    Tomorrow we are driving from Langford to Gabriola Island just for the day, so we'll see if I can finally drain it on the way there although I doubt it since it's a highway trip.
    EDIT: I have rarely seen 7 bars since. Usually 5 or 6 but even 4 bars is much more common than 7 bars.
    3 people like this.
  7. plugmein2
    plugmein2 New Member
    114
    124
    Salt Lake City, UT
    2 MONTHS DRIVING WITH THE ENGINER PHEV KIT!!!
    As of 10-14-09 I will have been driving with the Enginer 4KW system for exactly 2 months. Here is what I've learned.
    1. I average about 90 mpg
    2. My batteries have balanced and now, I just plug-in and go. I don't even check them anymore. (Well maybe just once a week:rolleyes:).
    3. Jack was amazing to work with and I am happy to give positive referrals.
    4. Always "charge" your OEM battery about 20-30 min before leaving your house for best results.
    5. Use the ICE to accelerate but switch to EV once you are at the speed you want.
    6. Highway speeds will kill your high mileage. Your average will be more in the 75-80 mpg.
    7. Enginer kit is most beneficial when you are city driving, ie...running errands, grocery shopping, taking kids to and from school, bank runs and so on.
    8. One full charge costs .28 cents and I usually only charge once a day. Total electricity cost for the month $8.40.
    I am very happy with my plug-in Toyota Prius!!:bounce:
    JOANNA
    9 people like this.
  8. ericbecky
    ericbecky Hybrid Battery Hero
    4,425
    3,300
    Madison, Wisconsin
    I love this one....
    I think we all have a skewed definition of "good" or "bad" gas mileage. :)
  9. plugmein2
    114
    124
    Salt Lake City, UT
    Now that fall is coming, I have noticed a decrease in mileage due to lower temperatures. I have lost about 20% because the engine needs time to warm up and the climate controls need the ICE to keep the interior at the desired temp.
    I will try to figure out how to combat the colder weather and still get the mileage I was getting last month. I will have to do some more testing. (No, I'm not going to install an engine block heater.:p)
    LATER,
    JOANNA
  10. mrbigh
    3,686
    699
    Long Island, NY
    If you know how to knit, you can do a personalized scarf for the engine..;)
  11. kiettyyyy
    kiettyyyy Plug-In Supply Engineer
    205
    167
    West Covina, CA
    I LOL'd a bit on the inside.
  12. TheForce
    3,461
    537
    Wheelersburg, Ohio
    A block heater will help a lot because the sooner you can get above 100F the sooner you can get 100MPG.
    During S1 now I'm only getting around 80MPG max since the coolant temp is starting below 100F. During the summer when the coolant temp is near 100F I was getting over 100MPG during S1.
  13. Fibb222
    Fibb222 New Member
    1,499
    99
    I have an EBH and grill blocking even though we are still well above zero here in Victoria.
  14. thefortunes
    thefortunes New Member
    29
    Wisconsin
    I typically block & start using the EBH when the highs are in the mid-50's. It makes a big difference (although it is a little funny to see the outside temperature display off by so much).
  15. mrbigh
    3,686
    699
    Long Island, NY
    I already have my front grills covered and my EBH connector ready for......
    the tricks is "how to" maximize your fuel efficiency beside of plug-in, getting it ready and go...
  16. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    How many miles do you drive per month? And what was your average MPG before the Plug-in mod?
  17. eximage
    eximage Junior Member
    Union City CA
    2001 Prius
    This is in addition to charging at the end of the day for how long?
  18. plugmein2
    114
    124
    Salt Lake City, UT
    I drive about 800 to 1000 miles per month, and my average before the plug-in was around 52mph.
    JOANNA
  19. plugmein2
    114
    124
    Salt Lake City, UT
    No, this means that before I begin a trip, I turn on the Enginer PHEV kit and let it "charge" the OEM battery to 80% before leaving. This gives me more power for EV mode than if I didn't pre-charge. And yes, this is in addition to charging the kit from the grid the night before.
    JOANNA
  20. linuxpenguin
    linuxpenguin Active Member
    352
    182
    What would you say your average speed is while using the Enginer PHEV kit?
    Andrew
