Enginer Plan B
Discussion in 'Prius PHEV Plug-In Modifications' started by cproaudio, Apr 9, 2011.
  1. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Pacific EV has another product that is specifically tailored to Enginer system. It's not shown on their web site.
  2. SFGiant-and-Plugin-Fan
    47
    Durham, NC
    Pacific EV has a BMS tailored to the current Enginer system with RF batteries. If interested you can send an e-mail to Cory at [email protected]. They have a draft user manual.
  3. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Will that BMS work better than MiniBMS? How does it compare to MiniBMS?
  4. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    miniBMS works very well for the enginer system, not sure how theirs would be better. certainly their ittyBMS looks virtually the same, but with 1.5A of shunting rather than 750ma.
  5. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    From the information I just received from Cory at PacificEv. There system is a plug and play system no need to hack your enginer kit to make it work.Which I think is a big plus also there system top balances and still uses your bms to bottom balance.
  6. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    Here is the manual for the PacificEV BMS attached. I got the OK from Cory before posting it.
    2 people like this.
  7. cproaudio
    2,401
    762
    CA
    OP has been updated with new information on the PacificEV's BMS. Looks like that BMS is custom designed specifically for Enginer kit using 2 cell logs as part of the balancer.
    I wouldn't call it hacking. But, it does require a little bit of rewiring mostly on the 120v input of the charger. The old BMS cuts power on the output of the charger. The new BMS cuts power on the input of the charger. Everything else just plugs in. Looking at the pdf file, it doesn't use the old BMS to bottom balance because the old BMS is being replaced by the new BMS.
  8. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    146
    Fort Worth, TX
    As far as the original post is concerned, if enginer goes out of business and the DC-DC converter fails, what do you do? Well, my suggestion would be to repair it. I've looked inside the converter, most of it is just off-the-shelf components. I would suspect that a failure would probably be with the areas that handle high voltage or high amperage. Any of those parts are going to be off-the-shelf. The hard part would be figuring out what broke. Once you've done that, just desolder it and solder in a replacement.
  9. caffeinekid
    caffeinekid Duct Tape Extraordinaire
    334
    45
    Houston
    When mine went bad, the most visibly damaged component besides the little (0.5A ?) fuse was a component pack on the input side. Unless you know what it contained, chances are you would be out of luck on a simple swap and solder....what with Murphy's Law and all.... :(
  10. Flaninacupboard
    1,297
    213
    Midlands - UK
    Yes it's difficult to read the component part number on a charred molten lump of toxic crap.
    Hopefully they -won't- go bust, but if they do they could release the design info a least.
  11. cproaudio
    2,401
    762
    CA
    We need to find the manufacturer of the converter. The charger I believe is made by Tiecheng Information Technology
  12. stefano5777
    stefano5777 Member
    380
    47
    In my opinion instead of trying to figure who makes the poorly made components we need to look for alternate manufacturer with compatible product made of superior quality. We know system is proven to work and that it is just a quality issue . We have found 2 replacement to the sometime faulty Bms we just need replacements to charger & converter.
  13. cproaudio
    2,401
    762
    CA
    Any LiFePo4 48V charger will work as long as it's under 1500W. That's the BMS16D's charging limit. My first post already listed a shop that carries a direct replacement. The only downside is they're based in China.
    We just need to find a converter manufacturer.
  14. stefano5777
    stefano5777 Member
    380
    47
    Cp I just switched to the PacificEv bms do you know if it has the same limitations?
  15. stefano5777
    stefano5777 Member
    380
    47
  16. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    too much money. requires too many batteries
    EVs require high current. series connected batteries provide higher voltage, parallel connected batteries provide higher current.
    because of this, higher current is the desired trait. so no matter what the voltage, if you do not have the current you will be basically accelerating from zero to 60 in minutes, not seconds.
    basically its like taking a garden hose to fight a house fire.
  17. corypev
    corypev New Member
    Seattle, WA
    Any charger which operates off a 120V 15A plug is limited to 1440W (which is 120*15*80%).
    Our BMS is limited to 15A max on the AC input.
    I'm working on adding our Enginer BMS to the website.
    Thanks everyone!
    Cory
  18. corypev
    corypev New Member
    Seattle, WA
    If you bought 5 and put their outputs in series, it'd work. Of course, it'd be cheaper to buy the plug-in-solutions (or whatever it's called now) 10kwh kit which is way better anyway.
  19. corypev
    corypev New Member
    Seattle, WA
    The advantage of the ittyBMS is twofold:
    1. With just a fault signal, you can't be sure every cell is full. So we added a second line indicating every cell is full. In combination with the EVCM, you can use any charger with any algorithm to charge your batteries (provided it goes to a high enough voltage) and the EVCM will turn it off at the right time.
    2. It has a two low voltage limits, the higher one allows you to exceed the limit for 15 seconds (changeable on order). This lets you accelerate hard for a limited time, but still prevents slow drains from taking your batteries to a very low SoC.
    But, as you know and the others mentioned, this isn't for Enginer kits but for EVs. It makes lead->Lithium conversions so easy, not to mention new installs.
  20. cproaudio
    2,401
    762
    CA
    I believe the BMS16D's charging current limit is limited to its internal relay rating. It is good enough for any level 1 charger or anything that can plug into a 110v outlet. If you replaced the BMS with alternative BMS such as MiniBMS with external relay or PacificEV's BMS with external relay, the charging rate is limited by the battery pack's charging limit and the relay you use. Most cheap batteries are limited to 1C for charging. I don't know the specs for RFE batteries. 1C on a 2KW kit is about 2,000 watts. 4KW kit is about 4,000 watts. At those ratings, you're looking at level 2 charging. Also the faster you charge, the shorter the service life becomes. Charging to too fast will damage the battery. That's why Nissan don't recommend using level 3 charging on a daily basis. As for the relay, you can use a heavy duty relay such as JQX-62F 120A DC 12V Coil PCB High Power Relay 12VDC for 4KW kit or 60 / 80 AMP RELAY SPDT SINGLE POLE DOUBLE THROW NEW 654 | eBay for 2KW kit.
