Entering Maintenance Mode (aka 12V Battery Check) without Switching Headlights ON/OFF
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 2009Prius, Mar 26, 2010.
  1. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Yes the battery should be OK though maybe slightly weak or wasn't fully charged when tested. You may want to do the test again next time after you have a long trip (several hours) and have the car off for a few hours. It may be a good idea to replace it in a few months before the winter comes as a preventive measure given the 5 year age. For the more adventurous type at least check it periodically. Good luck!
    TsKarma and Michgal007 like this.
  2. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    Thanks. Car wasn't driven for two days when I checked it. I will check it again on Friday after I do a 2 hour drive. Car becomes 5 years in August, so I want to wait until then if possible. :)
  3. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    If you want to be a good mommy to Pria order the battery today so you'll have a birthday present for her :rolleyes:
  4. Michgal007
    1,321
    98
    Macon, GA
    Definitely. She gets new shoes in August too!
    She is getting a dent fixed today and being detailed/bumper refinished tomorrow. :D
  5. Michgal007
    1,321
    98
    Macon, GA
    Checked immediately after driving for 2 hours and it was 12.3V. :)
  6. Mendel Leisk
    41,448
    I find a charger (or two) and a digital voltmeter very handy.
  7. 2009Prius
    2,705
    512
    63
    Usually we wait for a few hours to let the surface charge dissipate before checking the voltage. But if you checked the battery with the headlights on for a minute or two and got 12.3V then the battery seems to be in excellent shape.
  8. Michgal007
    1,321
    98
    Macon, GA
    I know, you said earlier to do that, but I forgot to come back after a couple of hours. :( I don't think I had the headlights on when I checked, but had them on during the 2 hour drive. I will do it right at some point. :) Thanks for your help.
  9. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Burnselk: Simple suggestion to improve mileage. Do the speed limit and use cruise control. BUT: is she ready for that?
  10. bgoodr
    bgoodr Junior Member
    What does "Now test the battery with some load" mean? When I press the power button again without stepping on the brake, the screen changes from the Vehicle Signal Check Mode screen back to the opening screen that looks the same as what it always does when I pressed the power button the first time.
    BTW, this is on a 2005 Prius with the built-in Navigation System. The voltage level on mine reads 10.0V without the headlights on (see camera snapshot of it at screenshot). That leads me to be believe it is time to replace my battery, because I am seeing the same start-up weirdness as reported in another post. I've recorded the issue with my Android phone and uploaded it to Prius 2005 Transmission lock is abnormal - YouTube and also uploaded a video showing what I have to do each time to workaround it at Prius 2005 Transmission lock is abnormal workaround - YouTube
    bg
  11. richard schumacher
    7,664
    1,046
    United States
    Turning on the headlights is plenty of load. But if yours is 10V when you first walk up to it with no load then it's near death already. Replace it immediately. Any day now the workarounds will stop working and you'll be stuck somewhere.
  12. bgoodr
    Great advice. Thanks Richard!
  13. cjcj1949
    cjcj1949 Junior Member
    uk
    The info in this thread is very good. Simple and accurate. I would do both tests as they really check out different problems. A battery can be ok once charged but have much reduced capacity. There could also be a higher than normal current drain or the battey could lose charge quite quickly. It depends how often you use the car as to how critical capacity is as the battery is being charged all the time the car is in Ready mode.
    It is probably a good idea to replace the battery after 4 years. My car is 4 years old and I think the capacity is down to 10AH.
    The charge current on any battery being charged at a fixed voltage is defined by the Battery not the charger. Good batteries will take more current at 14V than old batteries which is why they charge slower. (For the same state of charge)
  14. essaunders
    essaunders Member
    195
    NH
    How do you get out of this mode? Does pushing and holding the display button do enough?
  15. uart
    uart Senior Member
    4,220
    1,211
    Australia
    So far I think the only known why to exit this mode is to power the car off (and back on again if required). That's the way I do it.
  16. koolingit
    koolingit Member
    158
    51
    Mocksville NC, USA
    That's how I do it. Press and hold the display button for more than five seconds and you'll see the start up screen. You can then let go of the display button and the radio will come back on (if it was turned on) and you're back in the normal display.
    2 people like this.
  17. essaunders
    essaunders Member
    195
    NH
    I just checked the reading on my 07. Right after driving I got 12.5v no load, down to 12v when headlights on.
    My concern stated the other day when the car wouldn't start. I think I didn't get the hatch completely shut the night before. No cabin lights on, though. The headlights seemed a bit dim as we tried to figure out what was going on. I think turning off the headlights is what allowed the car to finally boot.
    Any one care to guess with me how close to end of life my 12v battery is?
  18. 2009Prius
    2,705
    512
    63
    I posted a recent test result here:
    http://priuschat.com/forums/gen-ii-...e-measurements-12v-battery-4.html#post1444163
    As you can see it dropped down to less than 11.6 V when headlights were on. (I didn't use the MFD display but I think it should give the same answer as PriiDash.) But I never has non-start problem. So this is really confusing: your battery maintains 12V with headlights on but gives you non-start problem; on the other hand mine drops significantly below 12V with headlights on but starts the car fine.
    The only thing I could think of is maybe the trunk light was on when the hatch wasn't closed completely? So the battery was depleted and later got charged back up.
    What if you turn both the headlight and the rear defrost on? Let's compare notes.
  19. uart
    uart Senior Member
    4,220
    1,211
    Australia
    It's never a good idea to try and start any car with the headlights on. Start the car first, put headlights on second.
    12.5/12.0 is ok, but it's a much more telling test if you do it after the car has been off for several hours or more.
    I like to do the test in the morning after the car's been off overnight. I like to bring it to "acc" mode, turn off all accessories (radio fan demister etc) and then enter the service menu to get a "no load reading". This is typically 12.3 volts for my battery but ideally would be slightly higher for a newer battery.
    Then I press the "on" button one more time to get to "Ig On" mode and record the second "under load" reading. Still no accessories, but the load is due to running all the ECU's etc. This is typically 11.9 to 12.1 volts for my battery, but a again a few point higher would be more typical with a newer battery.
    Finish the test by pressing the brake pedal and "On" one more time to get ready mode. The DC-DC converter is now charging the battery and the voltage should be around 13.8 to 14.2 volts. This doesn't really tell us too much about the battery but ensures that the charging system is working correctly.
  20. Starkie
    Starkie Junior Member
    83
    Northern California
    I wish I'd seen this a week ago.
    Thanks for the extremely useful post.
    I like the idea of secret buttons also.
    Will try this later today.
