Environment control (heating)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Piotrus Pan, Dec 1, 2014.
  1. Piotrus Pan
    Piotrus Pan Member
    126
    46
    Luxembourg
    Hi everyone.
    Winter is coming so I often use heating in "Auto" mode but that mode seems to be only working when the air outlet is directed to front window and feet. When I change it to face and feet or any other than the default, Auto turns off, is that normal?
    Thanks in advance.
    52,784
    good question. i don't use auto, so no idea. what does the o/m say?
  3. gliderman
    gliderman Active Member
    751
    225
    Auto is auto. If you want to control it, then it isnt auto, it is manual. :whistle:
  4. Piotrus Pan
    Piotrus Pan Member
    126
    46
    Luxembourg
    The manual says what the environment buttons do but not how they interact with each other unfortunately.
  5. Piotrus Pan
    Piotrus Pan Member
    126
    46
    Luxembourg
    Yes, I understand what you are saying but it's an automatic environment control, why would it matter if the air is coming from window vents or chest vents?
  6. bisco
    52,784
    that's a good point, i don't think the car knows when the windows need defrosting or if your fingers are cold. that's why i use manual.
  7. bisco
    52,784
    after you change it, what happens if you hit auto again, does it switch back to feet/window?
  8. gliderman
    751
    225
    Yep. It is programmed to do what Toyota thinks is right. I know that not everyone wants the heat on their feet all the time in the winter. Or the A/C on their face in the summer. But that is the way of the Toyota world. Now take control and use it any way you want with the manual setting, and show Toyota who is boss!
  9. Piotrus Pan
    Piotrus Pan Member
    126
    46
    Luxembourg
    It's like this:
    Auto ON -> Vents blow on window/feet
    Changing "Mode" to chest/feet (or any other) -> Auto turns OFF
    Switching Auto ON again -> Vents go back to window/feet
  10. bisco
    52,784
    that's what i was afraid of. makes no cents.
  11. Piotrus Pan
    Piotrus Pan Member
    126
    46
    Luxembourg
    Hello everyone.
    I think I know why this Environment Control works so strange.
    Summer is near and it's getting warmer. When the temperature outside exceeds around 10 degrees Celsius the Environment Control no longer forces air going to the front window. When the temperature is 10 degrees you can have "Automatic Environment Control" and change the air flow without turning "Auto" off.
    I guess that Toyota assumes in winter you always want to have your air going on the front window.
    Cheers!
  12. bisco
    52,784
    dang, i think you nailed it, thanks!(y)
