Environmental News
Discussion in 'Environmental Discussion' started by tochatihu, Oct 22, 2015.
  1. tochatihu
    tochatihu Senior Member
    9,987
    3,856
    Kunming Yunnan China
    2001 Prius
    I would guess that S Calif policies, resources, and resource allocations will be changed. The current fires will probably end up being costliest US disaster following a few recent hurricanes.
    52,863
    why can't they pump water out of the pacific?
  3. frodoz737
    frodoz737 Top Wrench
    4,807
    2,561
    33
    CAL FIRE is a region unto itself. The only time any of the 4 US Agencies are called in is when all hell breaks loose...and even they are usually delegated to working as deucers. News story if you want to look it up. Oregon Engine Crews held back because they don't meet CA smog requirements. :rolleyes:
  4. tochatihu
    9,987
    3,856
    2001 Prius
    Fighting these fires with seawater has been in recent news.
    There are abundant freshwater reservoirs near these fires. Reservoirs are quite full because of rains in earlier two years. Whenever wind conditions allowed aircraft to fly, that's what was done.
    Seawater corrodes pumping equipment. Seawater damages vegetation regrowth and alters soil chemistry in ways that might be harmful.
  5. bisco
    52,863
    more harmful than letting it burn?
  6. Trollbait
    12,831
    Then it becomes a structure fire when it reaches the city.
    Salt water is hard on equipment, assuming they have the equipment. Towns with hydrant networks don't maintain a fleet of tanker trucks, and it takes experience to field them for best effect.
    Then only one fire is next to the ocean, and it extends s few miles inland. Then rest are farther away. In the case of planes, the ocean tends to have rougher surface conditions. Scooping up a payload of seawater might be more difficult.
    To the native plants it is. They evolved to survive with the fires. Some plants need them for the next generation of seeds to germinate.
  7. tochatihu
    9,987
    3,856
    2001 Prius
    #2507 tochatihu, Jan 15, 2025
  8. tochatihu
    9,987
    3,856
    2001 Prius
    #2508 tochatihu, Jan 15, 2025
  9. bisco
    52,863
    might be worth weighing the cost of new supply lines from the ocean vs other future solutions
  10. hill
    9,039
    I'm sure the dozens that burned to death would choose salty soil over perishing.
    Then again, 20/20 hindsight means proper forestry / management would have gone a long way
    Then again if a governor takes pride in providing sanctuary state status, along with being a great place to be homeless, the budget only goes so far. Who knew - that virtue signaling could be so expensive
    #2510 hill, Jan 16, 2025
  11. Prodigyplace
    12,715
    11,848
    Central Virginia
    He has made it a great place for MORE homeless now...
  12. Trollbait
    12,831
    Could look into it for fighting the structure fire, but more water would not have helped with hurricane strength winds fanning the flames.
    The Seaside Heights boardwalk was rebuilt after Sandy. It caught fire soon after on a windy day. Not hurricane strong, but strong enough that water alone wasn't stopping it. The fire department ended up tearing down stands and the boardwalk to make a fire break in order to contain the fire. Doing the same in LA would mean a whole lot of houses.
  13. tochatihu
    9,987
    3,856
    2001 Prius
  14. hill
    9,039
    Having had our 1st Nashville home burn down (careless renters), the equally hard part is still ahead, fighting with insurance companies to compensate for all that folks lost. We chose to just sell the bare land .....
    rather than have to remember the bad experience & so moved two or more modern part of town with a home that has fire sprinklers integrated inside.
    Satellite view shows the empty lot & street view so old it shows me out mowing the front yard.
    #2514 hill, Jan 16, 2025
  15. tochatihu
    9,987
    3,856
    2001 Prius
    Wildland fire passing urban interfaces merits separate discussion. Next big burn, I'll start that unless someone else does sooner.
  16. bwilson4web
    16,538
    Slightly related, I'm having a solar roof installed and the team is laying the new power cables in the attic. So I'm add two, smoke detectors in that space. One on the Northwest corner nearest the added electronics and the second over where the new "smart panel" replacing the existing one.
    The smart panel (SPAN panel) has electronic load circuit control and network management. The single most expensive part, it will isolate the heavy load circuits like EV charging, oven, and range ... the 240 VAC power circuits when grid power goes out. This prevents overloading the storage battery in the solar array.
    I will ask the contractor if there is a recommended smoke detector that might integrate with the SPAN panel.
  17. tochatihu
    9,987
    3,856
    2001 Prius
    Global trust in scientists:
    https://www.nature.com/articles/s41562-024-02090-5
    Pop right down to Figure 1. Egypt and India are the possibly surprising leaders. Australia, NZ, US, UK, Sweden, Denmark do not surprise (me). Norway, Netherlands, Germany, Switzerland seem low (to me).
    Overall sample size is large, but maybe not impressively large in each country.
  18. tochatihu
    9,987
    3,856
    2001 Prius
  19. tochatihu
    9,987
    3,856
    2001 Prius
  20. tochatihu
    9,987
    3,856
    2001 Prius
    My word of the day is graupel:
    Graupel Isn't Snow, Nor Sleet, Nor Hail, So What the Heck Is It? | HowStuffWorks
    Because graupel is now falling in Kunming. Not a lot, and ground is melting it on arrival. Cars are retaining their decorations. We are 25o N latitude here, so just a bit outside the Tropics. But at 2000 meters and close as the wind flies to much higher land. During my time here there has been enough snow 3 times to build snowpersons (by children who were quick enough). This is the second graupel I have seen.
    None of those compare to excitement from summertime hail, seen here only once by me. Hail is among the most exciting things that this planet's atmosphere can conjure. I hid from wild hail in Texas longer ago, and some readers will have better stories.
    Graupel is a quieter thing, more like Sandburg's feline fog.
    wxman likes this.
