Environmental News
Discussion in 'Environmental Discussion' started by tochatihu, Oct 22, 2015.
  1. bisco
    52,849
    we're getting a lot more great whites around here. jellyfish are often a problem.
    when i was a kid, i spent every sumer day in the ocean with no ill effects. unless you can blame my mental state on seawater
  2. Trollbait
    12,825
    The great whites are making a come back. The area of NJ where the shark attacks that inspired Jaws was once a white shark pupping ground.
  3. hill
    9,038
  4. Trollbait
    12,825
    If you like your scallops chewy like gristle.
  5. tochatihu
    tochatihu Senior Member
    9,982
    3,851
    Kunming Yunnan China
    2001 Prius
    Agricultural yields have been changed by climate. Weather. Er, conditions:
    Climate change has likely already affected global food production
    "Our results show that impacts are mostly negative in Europe, Southern Africa and Australia but generally positive in Latin America. Impacts in Asia and Northern and Central America are mixed."
    This is ~1% scale. Only newsworthy for folks who anticipate such changes are off in the future, or will not happen.
  6. tochatihu
    9,982
    3,851
    2001 Prius
    Big offshore wind farm:
    Link
    May I also say that the word "epicenter" is very often misused as it was here.
    #1007 tochatihu, Jun 3, 2019
  7. bisco
    52,849
  8. tochatihu
    9,982
    3,851
    2001 Prius
    C'mon, you know this. Earthquake forces are centered some distance below the surface. That's the center. A line drawn straight up from that is epicenter (upon or on the surface of).
    But it soundz kool and seems more flashy than just saying "center". There are so many compelling things to communicate in science journalism, without such games.
  9. tochatihu
    9,982
    3,851
    2001 Prius
    Another mosquito engineering, separate from @989:
    Here mosquito genomes are directly modified using CRISPR. Offspring are certain to carry modification because of gene drive (which may be GENE DRIVE).
    Risk here, apparently, is that some other insect might get "doublesex" by horizontal gene transfer (involving bacteria or viruses). All of them would die; not necessarily a desired outcome.
    It is interesting to speculate what might happen if two different engineering projects were done in a particular area. I do not find such experiments.
  10. tochatihu
    9,982
    3,851
    2001 Prius
    With all this talk about DNA :) I enjoyed seeing this:
    Extraction: DNA from strawberries - CSMonitor.com
    It is a well-written description of an easy science thing. Granted, it may seem boring to look at DNA sludge. But you can put it in a little bottle and spread it around the next crime scene you happen to visit. Forensics will later be perplexed by this.
    "Why were there so many strawberries and where did they go?"
    Trollbait likes this.
  11. tochatihu
    9,982
    3,851
    2001 Prius
    Folks I know were examining environmental DNA (meaning collection from wherever, not from a particular organism) from Tibet. They found sequences specific to dolphins. Or maybe it was porpoises. Anyway, a similar chicanery may have occurred.
  12. tochatihu
    9,982
    3,851
    2001 Prius
    As you now know, weirdly huge modern strawberries have 8 DNA copies. They are 8-ploid. I looked around for 16-ploids (which would be even better for chicanery) but no luck.
    Anyway now I understand how seedless watermelons 'work'. Comforting because when I first saw them I thought abomination!
  13. bisco
    52,849
    have they figured out the square watermelons yet?
  14. tochatihu
    9,982
    3,851
    2001 Prius
    Oh gawd yes. Make fruit whatever shape by letting baby fruit develop inside shaped containers. Again I rather suspect you knew this.
    Growers of huge pumpkins (up to 1 ton now?) have not yet caught on that they could be shaped like whales, etc. Would require a whale-shaped bolt-together mold, but there may be people with even more free time than you or I.
  15. bisco
    52,849
    not possible, unless they've a hot tub time machine
  16. tochatihu
    9,982
    3,851
    2001 Prius
    An empirical argument: Absence of whale-shaped pumpkins is evidence against time travel.
    do not know what other people chat about in bars but for bisco and tochatihu it would be weird.
  17. Trollbait
    12,825
    Guess it's roommate to penultimate.
    How high was their confidence? One bit of incomplete DNA may get hits from a database far from its actual source.
    I got a hit for Yersinia pestis from back ground flora in raw milk once. This guy was the more exciting find.
    Paenibacillus vortex - Wikipedia
  18. tochatihu
    9,982
    3,851
    2001 Prius
    I really do not know the answer. Series of software steps (called workflow -- trendy!) remove a lot of primer-amplification artifacts. Sometimes a conscious being (terrestrial or otherwise) is still needed as observer.
  19. Zeppo Shanski
    Zeppo Shanski Active Member
    311
    192
    Chicagoland
