Environmental News
Discussion in 'Environmental Discussion' started by tochatihu, Oct 22, 2015.
  1. bisco
    52,854
    is that climate or weather?
  2. Zeppo Shanski
    Zeppo Shanski Active Member
    311
    192
    Chicagoland
    Climate
    From Wikipedia, the free encyclopedia
    This page presents a general overview of Earth's climate system. An introduction to how Earth's climate can change is found at Climate change, and discussion of the current warming of the climate system is presented at global warming. For other uses of "climate", see Climate (disambiguation)
    Climate is defined as the average state of everyday's weather condition over a period of 30 years. It is measured by assessing the patterns of variation in temperature, humidity, atmospheric pressure, wind, precipitation, atmospheric particle count and other meteorological variables in a given region over long periods of time. Climate differs from weather, in that weather only describes the short-term conditions of these variables in a given region.
    A region's climate is generated by the climate system, which has five components: atmosphere, hydrosphere, cryosphere, lithosphere, and biosphere.
    The climate of a location is affected by its latitude, terrain, and altitude, as well as nearby water bodies and their currents. Climates can be classified according to the average and the typical ranges of different variables, most commonly temperature and precipitation. The most commonly used classification scheme was the Köppen climate classification. The Thornthwaite system, in use since 1948, incorporates evapotranspiration along with temperature and precipitation information and is used in studying biological diversity and how climate change affects it. The Bergeron and Spatial Synoptic Classification systems focus on the origin of air masses that define the climate of a region.
    Paleoclimatology is the study of ancient climates. Since direct observations of climate are not available before the 19th century, paleoclimates are inferred from proxy variables that include non-biotic evidence such as sediments found in lake beds and ice cores, and biotic evidence such as tree rings and coral. Climate models are mathematical models of past, present and future climates. Climate change may occur over long and short timescales from a variety of factors; recent warming is discussed in global warming. Global warming results in redistributions. For example, "a 3°C change in mean annual temperature corresponds to a shift in isotherms of approximately 300–400 km in latitude (in the temperate zone) or 500 m in elevation. Therefore, species are expected to move upwards in elevation or towards the poles in latitude in response to shifting climate zones".
    Climate (from Ancient Greek klima, meaning inclination) is commonly defined as the weather averaged over a long period. The standard averaging period is 30 years, but other periods may be used depending on the purpose. Climate also includes statistics other than the average, such as the magnitudes of day-to-day or year-to-year variations. The Intergovernmental Panel on Climate Change (IPCC) 2001 glossary definition is as follows:
    The World Meteorological Organization (WMO) describes climate "normals" as "reference points used by climatologists to compare current climatological trends to that of the past or what is considered 'normal'. A Normal is defined as the arithmetic average of a climate element (e.g. temperature) over a 30-year period. A 30 year period is used, as it is long enough to filter out any interannual variation or anomalies, but also short enough to be able to show longer climatic trends." The WMO originated from the International Meteorological Organization which set up a technical commission for climatology in 1929. At its 1934 Wiesbaden meeting the technical commission designated the thirty-year period from 1901 to 1930 as the reference time frame for climatological standard normals. In 1982 the WMO agreed to update climate normals, and these were subsequently completed on the basis of climate data from 1 January 1961 to 31 December 1990.
    The difference between climate and weather is usefully summarized by the popular phrase "Climate is what you expect, weather is what you get." Over historical time spans there are a number of nearly constant variables that determine climate, including latitude, altitude, proportion of land to water, and proximity to oceans and mountains. These change only over periods of millions of years due to processes such as plate tectonics. Other climate determinants are more dynamic: the thermohaline circulation of the ocean leads to a 5 °C (9 °F) warming of the northern Atlantic Ocean compared to other ocean basins. Other ocean currents redistribute heat between land and water on a more regional scale. The density and type of vegetation coverage affects solar heat absorption, water retention, and rainfall on a regional level. Alterations in the quantity of atmospheric greenhouse gasesdetermines the amount of solar energy retained by the planet, leading to global warming or global cooling. The variables which determine climate are numerous and the interactions complex, but there is general agreement that the broad outlines are understood, at least insofar as the determinants of historical climate change are concerned.
    52,854
    thanks, i keep confusing the two
  4. Zeppo Shanski
    311
    192
    Chicagoland
    Weather
    This article is about the atmospheric process. For the geological process, see Weathering. For other uses, see Weather (disambiguation) and Weather systems (disambiguation).
    Weather is the state of the atmosphere, describing for example the degree to which it is hot or cold, wet or dry, calm or stormy, clear or cloudy. Most weather phenomena occur in the lowest level of the atmosphere, the troposphere, just below the stratosphere. Weather refers to day-to-day temperature and precipitation activity, whereas climate is the term for the averaging of atmospheric conditions over longer periods of time. When used without qualification, "weather" is generally understood to mean the weather of Earth.
    Weather is driven by air pressure, temperature and moisture differences between one place and another. These differences can occur due to the sun's angle at any particular spot, which varies with latitude. The strong temperature contrast between polar and tropical air gives rise to the largest scale atmospheric circulations: the Hadley Cell, the Ferrel Cell, the Polar Cell, and the jet stream. Weather systems in the mid-latitudes, such as extratropical cyclones, are caused by instabilities of the jet stream flow. Because the Earth's axis is tilted relative to its orbital plane, sunlight is incident at different angles at different times of the year. On Earth's surface, temperatures usually range ±40 °C (−40 °F to 100 °F) annually. Over thousands of years, changes in Earth's orbit can affect the amount and distribution of solar energy received by the Earth, thus influencing long-term climate and global climate change.
    Surface temperature differences in turn cause pressure differences. Higher altitudes are cooler than lower altitudes, as most atmospheric heating is due to contact with the Earth's surface while radiative losses to space are mostly constant. Weather forecasting is the application of science and technology to predict the state of the atmosphere for a future time and a given location. The Earth's weather system is a chaotic system; as a result, small changes to one part of the system can grow to have large effects on the system as a whole. Human attempts to control the weather have occurred throughout history, and there is evidence that human activities such as agriculture and industry have modified weather patterns.
    Studying how the weather works on other planets has been helpful in understanding how weather works on Earth. A famous landmark in the Solar System, Jupiter's Great Red Spot, is an anticyclonic storm known to have existed for at least 300 years. However, weather is not limited to planetary bodies. A star's corona is constantly being lost to space, creating what is essentially a very thin atmosphere throughout the Solar System. The movement of mass ejected from the Sun is known as the solar wind.
    On Earth, the common weather phenomena include wind, cloud, rain, snow, fog and dust storms. Less common events include natural disasters such as tornadoes, hurricanes, typhoons and ice storms. Almost all familiar weather phenomena occur in the troposphere (the lower part of the atmosphere). Weather does occur in the stratosphere and can affect weather lower down in the troposphere, but the exact mechanisms are poorly understood.
    Weather occurs primarily due to air pressure, temperature and moisture differences between one place to another. These differences can occur due to the sun angle at any particular spot, which varies by latitude from the tropics. In other words, the farther from the tropics one lies, the lower the sun angle is, which causes those locations to be cooler due the spread of the sunlight over a greater surface. The strong temperature contrast between polar and tropical air gives rise to the large scale atmospheric circulation cells and the jet stream. Weather systems in the mid-latitudes, such as extratropical cyclones, are caused by instabilities of the jet stream flow (see baroclinity). Weather systems in the tropics, such as monsoons or organized thunderstorm systems, are caused by different processes.
    Because the Earth's axis is tilted relative to its orbital plane, sunlight is incident at different angles at different times of the year. In June the Northern Hemisphere is tilted towards the sun, so at any given Northern Hemisphere latitude sunlight falls more directly on that spot than in December (see Effect of sun angle on climate). This effect causes seasons. Over thousands to hundreds of thousands of years, changes in Earth's orbital parameters affect the amount and distribution of solar energy received by the Earth and influence long-term climate. (See Milankovitch cycles).
    The uneven solar heating (the formation of zones of temperature and moisture gradients, or frontogenesis) can also be due to the weather itself in the form of cloudiness and precipitation. Higher altitudes are typically cooler than lower altitudes, which the result of higher surface temperature and radiational heating, which produces the adiabatic lapse rate. In some situations, the temperature actually increases with height. This phenomenon is known as an inversionand can cause mountaintops to be warmer than the valleys below. Inversions can lead to the formation of fog and often act as a cap that suppressesthunderstorm development. On local scales, temperature differences can occur because different surfaces (such as oceans, forests, ice sheets, or man-made objects) have differing physical characteristics such as reflectivity, roughness, or moisture content.
    Surface temperature differences in turn cause pressure differences. A hot surface warms the air above it causing it to expand and lower the density and the resulting surface air pressure. The resulting horizontal pressure gradient moves the air from higher to lower pressure regions, creating a wind, and the Earth's rotation then causes deflection of this air flow due to the Coriolis effect. The simple systems thus formed can then display emergent behaviour to produce more complex systems and thus other weather phenomena. Large scale examples include the Hadley cell while a smaller scale example would be coastal breezes.
    The atmosphere is a chaotic system. As a result, small changes to one part of the system can accumulate and magnify to cause large effects on the system as a whole. This atmospheric instability makes weather forecasting less predictable than tides or eclipses. Although it is difficult to accurately predict weather more than a few days in advance, weather forecasters are continually working to extend this limit through meteorological research and refining current methodologies in weather prediction. However, it is theoretically impossible to make useful day-to-day predictions more than about two weeks ahead, imposing an upper limit to potential for improved prediction skill.
  5. bisco
    52,854
    so that's weather then. same here, been raining since last august
  6. Zeppo Shanski
    311
    192
    Chicagoland
    That's why I've posted both. I was gonna post something much more succinct and simple, but after more thinking I decided that my comment might be mistakenly be considered rude, coarse, insulting, improper and/or inappropriate et al.
    Here ... see what you think: "GFY.".
  7. bisco
    52,854
    thanks. i'll bookmark this and try to refer to it when reading about climate and weather event.
    how do we differentiate normal bad weather with weather affected by climate change, first time occurrence in recorded history?
  8. Zeppo Shanski
    311
    192
    Chicagoland
    Research it yourself Grasshopper.
    ... is your friend.
  9. bisco
    52,854
    but you're so good at it, that's the same thing doc keeps telling me :unsure:
  10. tochatihu
    tochatihu Senior Member
    9,982
    3,851
    Kunming Yunnan China
    2001 Prius
    I think youse guys are just goofing around. Climate is a cumulative probability distribution of weather events. One decides what window of weather events to include, with 30 years seen as a generally useful period.
    If a weather event has not occurred in previous 30 years its probability within that distribution cannot be assessed. So one would expand time window. If enough data are available, and a similar is found, then one has a quantitative handle on its rarity. Events becoming more frequent (or rare) support notion that climate is changing. Dimension of time is then present in analysis where it mostly was not before.
    Concepts like "500-year floods" are more squishy. Done with probits, their results are seen as accurate until they are found to be not.
    Merkey likes this.
  11. bisco
    52,854
    and then, we have to figure out if it is 'man made' or not
  12. tochatihu
    9,982
    3,851
    2001 Prius
    That part is called 'attribution'. It is controversial mostly because acceptance of climate 'shift' by humans it not unanimous.
    This is why reading on your own is valuable. You get to develop your own view of evidence without others' influence. Different from definition of terms (that you pretend not to know). Definitions are not changed as they pass through communication chains (that's the idea) so they may as well come to you indirectly.
  13. bisco
    52,854
    or just err on the side of caution. it isn't as much of a burden as some would have you believe
  14. tochatihu
    9,982
    3,851
    2001 Prius
    err on the side of caution is not only a two-edged sword, the handle is also sharp.
    One can read many words to the effect that fossil fuel energy generation must increase, specifically to assist energy-poor people/regions. Such assertions are not wrong but neither are they complete.
  15. bisco
    52,854
    how is that being cautious?
  16. tochatihu
    9,982
    3,851
    2001 Prius
    If you look across countries, you may form the opinion that more than 0.7 gigajoules per capita allows access to 'developed country' status. Less does not and there are many countries with less.
    It would be incautious to not do something about that.
  17. bisco
    52,854
    if it is bad for us, why would we wish it on others?
  18. tochatihu
    9,982
    3,851
    2001 Prius
    It appears we are communicating imperfectly.
  19. tochatihu
    9,982
    3,851
    2001 Prius
    Just for fun see
    https://www.indexmundi.com/g/r.aspx?v=81000
    Zambia, wow. Are they doing Star Trek type stuff?
    Other sources suggest <700 kwh/year per capita, so it is probably a 6-orders-of-magnitude error. Which somebody ought to notice, I'd say.
  20. bisco
    52,854
    link doesn't work, but why not bypass fossils and go straight to newables?
