Environmental News
Discussion in 'Environmental Discussion' started by tochatihu, Oct 22, 2015.
  1. bwilson4web
    16,535
    I really need the sensor density as a function of area (standard units are OK) and the total area.
  2. tochatihu
    tochatihu Senior Member
    9,982
    3,851
    Kunming Yunnan China
    2001 Prius
    double whatsit
  3. tochatihu
    9,982
    3,851
    2001 Prius
    Triple whatsit - a record attempt?
  4. bwilson4web
    16,535
    Perhaps I misunderstood. I thought you were planning some testing that needed an array of soil water measurements.
  5. tochatihu
    9,982
    3,851
    2001 Prius
    I absolutely will. After sensors are speaking, there will be trays of (quite unusual) Honghe soil with controlled wetness and sensors no closer than 20 cm. Because if closer they may notice each other.
    I see three stages. First is hardware/software integration. Second is sensor calibrations under strict controls. Third is deployment in actual field soils where I am changing things.
  6. bwilson4web
    16,535
    An interesting problem, I'll take a closer look.
  7. tochatihu
    9,982
    3,851
    2001 Prius
    Arduinos, MUXs and sensors have been ordered. I wanted to get them from (more or less) trusted domestic suppliers but my employer has rules. Oddly enough they point to purchasing from Taobao. It is a dimly illuminated pit, so boxes might come filled with styrofoam packing & nothing else.
    Some Taobao suppliers play fair, but by no means all.
    Dense soil measurements are part of big-data agriculture and getting attention recently. But pointing towards high-priced equipment. Not a good fit for sub-industrial-scale agriculture. This is an intentionally disruptive plan.
    bwilson4web likes this.
  8. bwilson4web
    16,535
    • Good news - you have students
    • Bad news - sometime cyber exposure leads to a change in careers
    In college, I got an "F" on my first Fortran course even though I'd completed every homework assignment. When I retook the course, I blew off the homework assignments and read the first half of the Fortran manual for the mid-term and all of it before the final, got an "A". The grade was based on a multi-guess quiz on Fortran syntax.
    I have never consider computers anything more than a 'game of chess'. Apparently this led to a long and well compensated career. But it short-circuited other interesting puzzles.
    #1128 bwilson4web, Dec 12, 2019
  9. tochatihu
    9,982
    3,851
    2001 Prius
    Arduino hardware and software are sold as easy enough for kiddies. So there is a risk if I can't make this work. Actually most Arduino projects seem silly to me. Probably just a poor demographic fit.
    Learning exercise for students is to bury soil sensors correctly vs. the normal lazy way. In this very rocky soil. Tools need to be utilized correctly. Paying $1000 for a tool does not remove that responsibility. Paying $2 instead makes it easier to teach.
  10. tochatihu
    9,982
    3,851
    2001 Prius
  11. bisco
    52,854
    excellent. entertaining and informative. kind of what i remember from the museum of science type of presentations.
  12. tochatihu
    9,982
    3,851
    2001 Prius
    For some reason I thought you'd mention Brazil nuts.
  13. bisco
    52,854
    you wouldn't get me in one of those towers though :eek:
  14. bisco
    52,854
    i was thinking, dang, brazil nuts come from brazil nut trees?
  15. tochatihu
    9,982
    3,851
    2001 Prius
    When I was at Oak Ridge I was very excited at possibility of sampling air from a 1000-foot tower. Unfortunately some radio engineer made a successful suicide from it, and they shut down access.
  16. bisco
    52,854
    might be time for the cia to take out bolsonaro
  17. tochatihu
    9,982
    3,851
    2001 Prius
    He called Greta a brat.
  18. tochatihu
    9,982
    3,851
    2001 Prius
    No 'likes' for posts mentioning suicide. Let's maintain a degree of decorum.
  19. bisco
    52,854
    does that put him in the same class as hill?:p
  20. bisco
    52,854
    so noted, i was liking your bravery
