Environmental News
Discussion in 'Environmental Discussion' started by tochatihu, Oct 22, 2015.
  1. tochatihu
    tochatihu Senior Member
    9,957
    3,845
    Kunming Yunnan China
    2001 Prius
  2. tochatihu
    9,957
    3,845
    2001 Prius
    fuzzy1 likes this.
  3. tochatihu
    9,957
    3,845
    2001 Prius
  4. wxman
    wxman Active Member
    636
    231
    Tennessee
  5. tochatihu
    9,957
    3,845
    2001 Prius
    For me as well! I was at Oak Ridge when Baldocchi et al. were doing initial instrumentation and analysis for eddy covariance.
    Now it comes as a 'kit' including software from Campbell Scientific or others. But problems in complex terrain and with uneven canopies have not all been solved.
    Eddy covariance wiki page is nicely done, but it is hard to avoid funny-looking math, So public at large is unlikely to share our enthusiasm :)
    Eddy covariance - Wikipedia
  6. wxman
    wxman Active Member
    636
    231
    Tennessee
    Yeah, I really haven't kept up with the research since retiring in 2012.
    Last I knew was that it didn't appear mixing heights followed the terrain very well. This was an issue for smoke dispersion in prescribed burns.
    Interesting that you worked in Oak Ridge. ORR is in NWS Morristown's CWA.
  7. tochatihu
    9,957
    3,845
    2001 Prius
  8. fuzzy1
    10,690
    Such a shield and optical window, or camera aperture, doesn't exist for neutrinos.
  9. bwilson4web
    16,516
    I wasn't thinking image as much as direction and intensity. Seeing the 'bright light' source. But it may be redundancy to the the path of failed robots.
  10. fuzzy1
    10,690
    I would clarify that the Arecibo Observatory is used not so much to find or identify NEOs, but rather to use its radar to more precisely refine the orbits of hazardous objects identified by other programs. For which projects are actually finding these objects, see here:
    Search Program
    NEO Discovery Statistics (bottom half of page, Near-Earth Asteroid Discoveries by Survey)
    Arecibo has a limited view of the sky, so cannot ping all suspects. While quite valuable -- the other optical systems measure only x and y coordinates, radar adds a z component -- I don't know that it is essential for this purpose.
    China is in the process of commissioning an even larger natural-bowl radio telescope, named FAST. But it appears to lack the radar transmitter that is so useful at Arecibo:
    Five hundred meter Aperture Spherical Telescope - Wikipedia
  11. fuzzy1
    10,690
    I hope this holds up. It takes one potential doomsday scenario off our plate.
  12. tochatihu
    9,957
    3,845
    2001 Prius
    FAST@110. No transmitter, correct. This is said to be disqualifying for 'planetary defense', but with accurate timing information from Arecibo, FAST could 'hear' echo and do the math.
    Such offline post processing will be used to image Milky Way central black hole in xray.
  13. bisco
    52,804
    haven't noticed any sinkholes lately.
  14. fuzzy1
    10,690
    With FAST being at nearly opposite longitude from Arecibo, the echos of nearby targets will return and vanish long before the receiver swings into view. Perhaps Australia could step up and use one of its steerable dish transmitters to illuminate targets for FAST? The latitude-longitude difference isn't nice (60 & 40 degrees, respectively, from Canberra DSN), so the transmitter must be aimed low to the horizon, but it should work.
    Of course, keeping Arecibo open would be far cheaper than building anything new. But it would also be nice to have some Southern Hemisphere facilities to view targets beyond the rather narrow horizons of Arecibo and FAST.
    #114 fuzzy1, Feb 19, 2017
    tochatihu likes this.
  15. tochatihu
    9,957
    3,845
    2001 Prius
    Ugeta like for pointing out longitude issue.
    If ever travel to Puerto Rico, plead for Arecibo 'backroom tour' where the large capacitors are. Power for outgoing radar. Wowee.
  16. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    That's because they are hiding right under you. Watch Out!
  17. bisco
    52,804
  18. tochatihu
    9,957
    3,845
    2001 Prius
  19. tochatihu
    9,957
    3,845
    2001 Prius
  20. tochatihu
    9,957
    3,845
    2001 Prius
