Environmental News
Discussion in 'Environmental Discussion' started by tochatihu, Oct 22, 2015.
  1. tochatihu
    tochatihu Senior Member
    9,989
    3,858
    Kunming Yunnan China
    2001 Prius
    Supersized shark megalodon was a tippy-top predator:
    Megalodon Teeth Reveal They Sat At The Highest-Ever Spot In The Marine Food Chain | IFLScience
    This will not surprise readers, but some will be interested in the nitrogen-isotope technique to identify upper edge of food webs.
    'Meg' went extinct about 3.5 million years ago. 'Modern' sharks may have depleted their food. Killer sperm whales (also extinct) probably competed for yummies. KSW would have laughed at Captain Ahab, tell you what.
    Anyway, if equipped with a time machine, do not travel to 5 million years ago. Whether on land or at sea, 100-kg meatbags were totally snack size then, and not fast enough, running or swimming.
  2. tochatihu
    9,989
    3,858
    2001 Prius
    52,863
    2 grandsons, one is 5 and the other 3, spend most of their day teaching me about dinosaurs. megalodon is one of their favorites.
    spent the day at the exhibit at the museum of science. it is amazing to me how fascinated they are
  4. Trollbait
    12,831
  5. ChapmanF
    19,039
    I don't think I'd trust anything that fish told me.
  6. fuzzy1
    10,714
    One of the other articles suggests that megalodons and great whites shared the top of the food chain. While the former may have been better able to eat the later, the later seems to have won the longer term survival battle.
    But now it seems that great whites are no longer the top of the food chain, at least near South Africa. Some orcas (killer whales), or at least one pair of them, seem to have developed a fondness for great white shark liver, causing many great whites to look for different territory:
    Orcas ripping great white sharks open off South Africa, says new study - CNN
  7. tochatihu
    9,989
    3,858
    2001 Prius
    pate ex-parte party
  8. tochatihu
    9,989
    3,858
    2001 Prius
  9. bisco
    52,863
    depends on what roids he's on
  10. fuzzy1
    10,714
    I've always wondered about how to relate this to those of us doing long distance rides here, longer than any Tour stage. But being just a recreational rider, not any sort of race caliber athlete, haven't looked into what sort of real numbers I can produce.
    That Tour stage is 103 miles long, with 15,580 feet of climb. Other stages (excluding shorter time trials and parade stages) are 80 to 137 miles. For comparison, major big rides here include RAMROD (Ride Around Mt. Rainier in One Day), 162 miles and almost 10,000 feet of climb, and STP (Seattle To Portland, 207 miles this year) but only ~5000 feet of climb (never more than 400 at once). I've not done the former, but many friends have. Most ordinary mortals enjoy the later over two days, but around 25% (a couple thousand riders) are masochistic enough to do it in one day. Including me, twice.
    At least for the later, it is emphasized that the event is a Ride, not a race, so finish times are not recorded. (Many riders start early, or avoid the massive crowd by starting at home and pedaling to the nearest point on course, so official timekeeping would be futile.) From overheard talk, I believe the leaders are finishing somewhere in the range of 9:30 hours. I needed 15:10 at age 45, and 15:45 at age 58, with little daylight remaining. But a larger fraction of my day must be spent in rest stops, so the speed differential isn’t as large as the times initially suggest.
    On that first ride, I was thrilled by a rolling average of 17 mph, while a younger coworker was disappointed to have fallen under 20 mph for the first time in his history (due to headwinds and less training).
    My rolling times were about 12 and 12.5 hours, while I’m guessing leaders took a bit under 9. The climbing energy (for a given weight) is the same, but in the end most of that is transferred into wind drag on our (generally not too steep) descents. Figuring wind drag as proportional to the square of speed, I’m putting barely half as much energy into wind drag as the leaders, and am taking longer to do it. So if they are averaging 300 watts all day, then I must be averaging under 110 to 125 watts. Those ratios certainly sound much less impressive.
    I hope to do this just once more (not this year), in my 60s, before getting too old. And hoping that point isn’t already passed.
  11. tochatihu
    9,989
    3,858
    2001 Prius
    Two starting points:
    Energy Efficiency of Bicycle Transportation
    How to Calculate the Power Used by a Bicycle - Better Bicycles
    I suppose that all those squiggles have been coded into a spreadsheet somewhere. With 'enter your weight, speed, and road slope' boxes and default values for road surface and mechanical friction (chain and wheel bearings). The latter with options to modify over plausible ranges. I suppose that such exists, but have not searched.
    Our Bob :) could do coast-down experiments on wide (approaching off-road) vs. super skinny tires. His wheelhouse.
    Tour de France and other pro races disallow bicycles below a minimum weight. But I betcha they have very slippery chains and wheel bearings.
  12. fuzzy1
    10,714
    The sample numbers there seem unreasonably high. As in, in my prime, I rode a decent distance at this speed (10 m/s, 22.4 mph), and am heavier, but there was no way I was putting out anywhere near this much 'best case' power, let along 'worst case':
    "If we had instead used the best case numbers from above, we would have calculated a power usage of approximately 696 W = 0.17 kcal/s, a factor of 3 improvement in efficiency."
    I stumbled across a biking calculator that gives numbers that seem more intuitively reasonable for the speeds I ride:
    Bike Calculator
    By this calculator, I was probably varying 150-200 W in the first quarter of the ride, dropping to 100-120 W in the last quarter, not accounting for the climbs. Well short of more serious riders, let alone racers. Speeds would be better if my back could tolerate the drop position all day, and with aerobars with brake levers (not shifters) on the ends.
  13. hill
    9,041
    After making several bike runs between LA county & San Diego County - switching from a Touring bike to a recumbent seems the best way to defeat drag (the lightning p-38). It took a bit of time to relearn the balance & quadricep muscle usage, but it ultimately shortened riding times. The thing is, the hardest battle to overcome was the fear of getting run over, being so close to the ground.
    Recumbent Bikes WhyCycle? - The impartial cycling advice site.
    And frankly, there's the vanity issue. Riding a recumbent makes one feel like a dork.
  14. bisco
    52,863
    it looks really awkward, and visibilty is definitely a problem. most have a flag flying, but still...
  15. tochatihu
    9,989
    3,858
    2001 Prius
    Yosemite's 'fireproof' Sequoias are again in the 2020s at risk of fire, and hundreds of fire fighters are battling to make the new climate normal not be so. Hoping for success there, surely. But even with best and unexpected efforts to limit +CO2, it will be fricking decades before this will not be 'a story' in future La Nina years.
    I'll not write off giant trees though. Seeds and genomes are well in hand. Time is long. Only we and our vision are short.
  16. tochatihu
    9,989
    3,858
    2001 Prius
    iplug likes this.
  17. tochatihu
    9,989
    3,858
    2001 Prius
  18. bisco
    52,863
  19. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    tochatihu likes this.
  20. tochatihu
    9,989
    3,858
    2001 Prius
    iplug likes this.
