EPA Estimated 640 Mile Driving Range
Discussion in 'Prime Fuel Economy & EV Range' started by Gen 3 for me, Mar 17, 2017.
  1. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    The Toyota website for the Prime states:
    Prius Prime has an impressive EPA-estimated total driving range of 640 miles [prime_2017_range_rating] and an EPA-estimated EV Mode [prime_hybrid_caution] range of 25 miles [prime_2017_ev_range] if only recharging once.
    My question is how far have Prime owners driven on one full charge and one full tank of gas. If you reached 640 miles or greater of total driving range how many EV miles or % EV ratio did you get, and at what typical speed did you drive in HV mode to achieve this?
    priuscatprimeguy likes this.
  2. john1701a
    john1701a Prius Guru
    12,757
    5,245
    57
    After 91,355 miles and 172 refills, the real-world average tank distance with my Prius PHV is 513 miles.
    That's as real as it gets. There's a wide mix of short drives, long trips, and top-offs. The variety represents the randomness encountered from everyday need, where you don't plan when. You just do when needed.
    With the Prius Prime, I'll be able to drive the entire commute with just electricity. There will be a lot of errand running with EV only too. The tank is larger as well. So, it wouldn't be much of a stretch to routinely expect +1,000 mile tanks.
  3. bwilson4web
    15,528
    600 miles - first tank, no charge, following trucks on I-81
    699 miles - second tank, no charge, following trucks on I-81 and 99 miles around town to empty
    Details: Prius Prime Plus in my hands | PriusChat
    Insirt, dalcon95 and priuscatprimeguy like this.
    49,520
    does epa run it dry, or just to the warning?
  5. Tideland2005
    Tideland2005 Member
    72
    34
    SoCal
    I gone 635 miles per tank on my 2005 Gen2 .... many times.
