1. brin wood
    brin wood Member
    100
    upstate NY
    Will disconnecting the 12V battery erase the codes and allow restart? Have been stranded twice in 12 months by car not going to ready at all. First time on arriving home.......2d time in the middle of nowhere...that required 90 mile tow to dealer on a Sunday. They scanned it and said they don't know why it happens but if I pay them they will chase all the possible causes....at my cost.
  2. JC91006
    16,937
    8,647
    Could this be as simple as having a bad 12v battery?
    To answer your question, YES. It'll erase the codes and if there's enough juice, it'll start. HOWEVER, if there's a code preventing the car to start, it's best you try to figure that out and not just erase the code.....just for your safety
  3. brin wood
    brin wood Member
    100
    upstate NY
  4. brin wood
    brin wood Member
    100
    upstate NY
    Dealer scan said could be 1 or more of 13 things and wants me to pay for each chase. Cost $100 for them to start it. All they did is clear the codes.
  5. bisco
    52,872
    how many miles on her?
  6. brin wood
    brin wood Member
    100
    upstate NY
  7. JC91006
    16,937
    8,647
    If they charged you to scan, they have the codes that pinpoint the problem. Ask them for it, you did pay for them
  8. brin wood
    brin wood Member
    100
    upstate NY
    Like I said, they said 13 things could do it. Just pay them for each pursuit.
  9. bisco
    52,872
    unfortunately, when someone spends time working on your car, they rarely do it for free, even if it's diagnosis. i would test the 12v as jc recommended.
  10. JC91006
    16,937
    8,647
    You can ask for the 13 codes......which is not likely to have. We'll run them down for you
  11. bisco
    52,872
    does it exhibit any other unusual behavior? mpg's okay?
  12. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    Ask for the DTC (code). I am willing to bet you have a P0AA6 and if you do, you will need to get a three digit info code to trace the location.
  13. brin wood
    brin wood Member
    100
    upstate NY
    I took 12V to advance auto. Load test said was better than new! Don't think that is the culprit.
    codes=DTC NO. P0AA6 INF CODE=526*1 and 611*2. trouble areas, frame wire,system main relay,system main resistor,HV battery assembly, Electric inverter compressor, Battery ECU, HV transaxle assembly,
    Inverter with converter assembly, Main battery cable, No. 2 main battery cable, No 2 frame wire, junction block.
  14. brin wood
    brin wood Member
    100
    upstate NY
    Runs just fine, MPG about 44.
  15. bisco
    52,872
    how is the connection from the battery neg post at the body?
  16. brin wood
    brin wood Member
    100
    upstate NY
    On the 12V?, just fine, I cleaned all the 12V connections.
  17. bisco
    52,872
    the connection at the other end of the wire where it goes to ground?
  18. brin wood
    brin wood Member
    100
    upstate NY
    Yes I did.
  19. bisco
    52,872
    okay. just curious, how old is the 12volt?
  20. brin wood
    brin wood Member
    100
    upstate NY
    Would it behoove me to try and contact TOYOTA? But, I don't know how to do that.
