1. bisco
    52,872
    you want to be 12.4 or above. a new one should be 13.0, we're talking with everything off for a few hours so there's no surface charge.
  2. brin wood
    brin wood Member
    100
    upstate NY
    Can I check the voltage under the hood or do I need to open the hatchback? or is the onscreen method ok?
    52,872
    under the hood is fine, screen can be iffy. put a voltmeter on it.
  4. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    Did you have the AC top up at the dealers or just an AC shop?
    Using the wrong oil in the AC will cause the problem you are having. Oil used should be ND11 not PAG. If the wrong oil was used you have a case against the shop that did the top up. This would require replacing virtually the complete AC sytem, condenser, evaporator, and electric pump.
    John (Britprius)
  5. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Close but no cigar.
    A new battery will read 12.6 to 12.8 volts when fully charged.
    Less is not OK and more is very unusual.
    Open the hood and connect the battery charger there.
    When the "green light" indicates a full charge, disconnect the charger and then DO NOT TOUCH THE CAR for about 4 hours.
    Seriously, keep the doors closed and the key FOBs at least 15 feet away.
    After that, the battery should read 12.6-12.8 volts.
  6. brin wood
    brin wood Member
    100
    upstate NY
    Will do tomorrow........it's only 12 above right now. Oh yeh, what green light??
  7. bisco
    52,872
    green light on the charger means it's done charging.
  8. brin wood
    brin wood Member
    100
    upstate NY
    my charger has no lights !
  9. bisco
    52,872
    then don't bother waiting for green.:p make sure your charger meets toyota specs!
  10. Easy Rider 2
    1,584
    258
    Ocala, FL
    Well that likely means that it is NOT an automatic tender type charger.
    Does it have a current meter ?
    If no lights and no meter......you should seriously consider getting a new one and using that one only sparingly.
  11. brin wood
    brin wood Member
    100
    upstate NY
    My charger does have a meter. It is a 6 amp with 50 amp? boost. When hooked up shows it is charging at 3 amps; and slowly goes down......
  12. bisco
    52,872
    6 amps may be too high for the prius battery, causing damage, but i'm not positive. there are good threads here on safe charging practices.
  13. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    3 amps and down is just fine. No worries. The Prius internal charger can do much more than that for brief periods. As long as the current tapers off, the battery is OK.
  14. brin wood
    brin wood Member
    100
    upstate NY
    Do you mean the battery is up to snuff and still good? Or protected from over charging.?
    thanks for your input.
  15. valde3
    valde3 Senior Member
    2,002
    751
    Finland
    If your charger is old type “stupid” charger. You really should monitor voltage with that charger and stop when it gets up to 14.4v. Measure the voltage with charger connected. That type of charger will break any maintenance free battery if left charging for too long. Normally you do see amp meter getting down when battery is full but its hard to know exact point.
  16. Easy Rider 2
    1,584
    258
    Ocala, FL
    Not necessarily.
    First, with that kind of charger, you need to disconnect it when the current gets down to about 1/2 amp for a half hour or so.
    Second, merely seeing that behavior doesn't in itself prove anything. After charging, it might not give up the charge properly......or it might self discharge most of the energy within a few hours.
  17. valde3
    2,002
    751
    Finland
    With the “stupid” charger you should first measure unconnected battery voltage. Then monitor voltage and amp meter while charging (you can only monitor amps if you know your charger well enough) and then check voltage sometime after charger is disconnected.
  18. nh7o
    1,686
    340
    Hawaii
    By OK, I meant, as a sealed battery, it won't overcharge at that amperage. If the amps goes down, at least there is not a shorted cell, which usually manifests by a continuous current draw, and the battery gets hot eventually. The battery may be sulfated and have high internal resistance, but your charger won't cause much change in that aspect.
    Britprius likes this.
  19. brin wood
    brin wood Member
    100
    upstate NY
    Today 1/11/15, I drove about 25 miles city and hiway. After car sat for 3 hrs. I did the in-car check on the display. Shows 12.1 V. and All green on the traction batt.
  20. bisco
    52,872
    you probably need a new 12 volt.
