ERC code
Discussion in 'Gen 3 Prius Main Forum' started by Safiya Barrington, Dec 4, 2017.
  1. Safiya Barrington
    Safiya Barrington New Member
    Trinidad and Tobago
    My car needed a diagnostic to find out what was wrong with it. Apparently the mechanics also removed the battery. Now the navigation screen/audio deck is locked. I was told this code is needed to unlock it. Please help me. I own a 2013 Toyota Prius
    52,855
    welcome!
    wow, never saw anything like that before. which battery did they remove?
    dealer, or private mechanic?
  3. Safiya Barrington
    Trinidad and Tobago
    I'm not sure which one, I think it's under the hood though. It's a private mechanic.
  4. BZzap!
    BZzap! Senior Member
    1,607
    878
    Have you tried to enter that code? Looks like you have verify the code by entering it in the second box. I would assume that the two boxes to the lower right are “YES” and “No”, or something to that effect.
  5. ChapmanF
    19,020
    I have to ask ... are you sure that isn't some aftermarket head unit? I've never seen anything in a Gen 3 Prius that looked like that from the factory....
    -Chap
  6. Elektroingenieur
    2,515
    3,288
    Three Touring
    From a Google search, this seems to be a fairly common problem, and I see you—or someone with the same picture you posted—already asked about this in another forum, where a user (in post #1298 on October 22) offered a downloadable program to calculate the code from the sixteen-digit value shown on the ERC Input Screen (ERC入力画面). Have you tried using this program? (Press 完了 after entering the code.)
    It’s a Toyota NSZT-W62G, sold only in Japan. The user’s manual (PDF) is available on toyota.jp.
  7. Safiya Barrington
    Trinidad and Tobago
    I didn't but I will try it
  8. Safiya Barrington
    Trinidad and Tobago
  9. Elektroingenieur
    2,515
    3,288
    Three Touring
    Navin and bisco like this.
  10. Safiya Barrington
    Trinidad and Tobago
    Elektroingenieur likes this.
  11. bisco
    52,855
    congrats!(y)
    Safiya Barrington likes this.
  12. Cheero
    Cheero New Member
    Czech
    2011 Aqua
    if anyone needs ERC code, here is an unlimited calculator, Google Play - Cheero08
