Erroneous fuel mileage readings
Discussion in 'Gen 3 Prius Main Forum' started by BZzap!, Jul 23, 2019.
  1. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Ride at the speed long long enough, SOC will go below 40% and ICE will come back on, then MPGs will melt away quick.
    #21 Grit, Jul 28, 2019
  2. Mendel Leisk
    42,378
    The AC relies on that massive front radiator (condenser) for cooling.
    Personally, I don't use any grill block once ambient temps are staying above 10C. With ambient temps below 10C, I'll typically block 50% of the lower grill. If ambient temp is steadily below 0C (rare here) I'll sometimes 100% block lower. Maybe.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Personally, I don't EVER block any part of the grill......EVER.
    If done wrong, it can actually increase your wind resistance and do exactly the opposite of what you want.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I know how an ac works so that’s why it’s detrimental to use ac with grill blocked.
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    How long in distance are your drives typically in miles?
  6. Mendel Leisk
    42,378
    All over the map, a lot of short trips though.
