Error Code 01-DC 1C6-95-1
Discussion in 'Gen 2 Prius Main Forum' started by Scott M. Bleeker II, Sep 3, 2018.
  1. Scott M. Bleeker II
    Scott M. Bleeker II New Member
    Fairfield NJ
    My 2005 Prius currently won't go into ready mode and shows pretty much every error light possible. There are no error codes on the OBDII side of things but there is one EMV code which is 01-DC 1C6-95-1. I have very recently replaced both the hybrid battery and the 12v, the latter of which is currently displaying a voltage of 12.3v. Any help deciphering the code and getting my car back up and running would be greatly appreciated.
    51,141
    12.3 is low, if you measured it after the car had been off a few hours.
    if it is not the 12v, you will need tech stream to read the codes.
    has it ever run since replacing the hybrid battery?
  3. JC91006
    16,672
    8,518
    If you replaced the hv battery with a refurbished unit, chances are the problem will be the hv battery again.
    It's not your 12v causing the problems.
    To be sure of the issue, you need to get the codes read. Whatever strange codes you posted are not read with a code reader
    #3 JC91006, Sep 3, 2018
  4. Scott M. Bleeker II
    Fairfield NJ
    I did have the hv battery replaced with a refurbished unit and I have been driving it around for about 2 months with no issue. If it is the hv the work should still be warrantied so I'll be calling the refurb place tomorrow. Also, the prius was in ready mode when the warning lights lit up and was displaying a voltage of 14v at that time. After immediately turning it off and on again it was displaying 12.3v and wouldn't go into ready. But is there any way to decipher those error codes without a proprietary code reader?
  5. PriusCamper
    PriusCamper Senior Member
    12,056
    4,893
    Pacific Northwest, USA
    EMV codes are related to the dashboard systems you use when you drive, not related to the vehicle not working... How did you try and read the codes? An advanced code reader like a Veepeak bluetooth and a quality app like Dr. Prius will find the sub-codes that a handheld auto parts store code reader can't read. And Toyota Techstream is an option but more of a hassle because of lousy windows software, knock off OBD2 hassles. If I were in your position I'd disconnect the 12volt. Put it on a cheap $10 trickle charger overnight and then then reconnect in the morning hopefully with the battery showing 13.8v full charge I suspect the battery being a little low isn't the problem, but in disconnecting for a while you're gonna reset all the systems, which is the same as rebooting a home computer. If you still don't have any codes to read and car won't start, I'd next take a look at the big orange switch on the hybrid battery to make sure it's correctly pressed down. Also make sure the 120amp fuse in its handle is still ok. I've had similar symptoms once when I failed to connect all the HV battery cables back together so it was an open circuit. Also give us more details about how long it's been since you last drove the car and if you noticed anything different last time you drove it.
  6. Scott M. Bleeker II
    Fairfield NJ
    I tried to read the codes with a cheap bluetooth OBDII scanner I got off of amazon and used Torque(Lite) for my attempts at reading. Would OBDII scanner you suggested be better than the one I currently have? the I last drove the car two days ago and everything seemed to be working perfectly fine, however when I did start it two days ago I noticed that there were only two "bars" on the display battery and once I drove down the block it dropped down to a single red bar despite the ICE running the whole time. It did eventually continue to charge to normal levels but it did make me nervous at the time. When I tried to start it today the display indicated the hv battery was half full. I just checked the orange disconnect and the fuse inside looked fine and I made sure I pressed it down and it clicked right when I re-inserted it. I don't currently have a trickle charger and I'm probably going to have to wait till tomorrow to buy one since everything around me is closed right now
    EDIT: I downloaded Dr. Prius and found HV Battery ECU error code: P0AA6
    Would you recommend purchasing a basic license for the app's battery diagnostic tools?
    #6 Scott M. Bleeker II, Sep 3, 2018
  7. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    Please let us know what company the refurbished battery is from.
  8. Scott M. Bleeker II
    Fairfield NJ
  9. ericbecky
    4,381
    3,242
    Madison, Wisconsin
    Thanks for sharing. Please keep us informed how this plays out.
    It does sound like the hybrid battery.
    Did you install it yourself?
    If they installed it, hopefully it covers the labor?
    If you had it shipped, let us know how it goes for shipping under warranty.
  10. JC91006
    16,672
    8,518
    There is probably a leaking module in your battery pack. But it'll be hard to convince those Falcon guys it's their battery. Their response will probably be it's not the battery causing the error so they won't cover it. But that's just my guess
  11. Scott M. Bleeker II
    Fairfield NJ
    I had them install it for a $200 up-charge at their shop. I'll probably attempt it myself on one of my future priuses(prii?), but this time I was in a pretty big rush to get it going and didn't have time to fumble through it and potentially make a big mistake.
  12. PriusCamper
    12,056
    4,893
    It's just the quality of the code reader, not really proprietary. You can learn more about the difference between junk readers and good ones here: Hybrid battery diagnostic and repair tool for Toyota and Lexus
    The additional information you've shared makes me think it's less likely that the hybrid battery is the problem. Any other symptoms? Anything different about the vehicle recently? As I said in previous post. Next step is to disconnect the battery for 10 minutes to see if a systems reboot has an effect on the problem.
  13. Scott M. Bleeker II
    Fairfield NJ
    Actually going to be heading in for the night now so I'll try disconnecting the battery tomorrow morning and getting a trickle charger for the 12v when shops around me open. And as far as I could tell everything was working perfectly fine besides what I mentioned before up until this problem. Thanks all for your help so far
    PriusCamper likes this.
  14. ericbecky
    4,381
    3,242
    Madison, Wisconsin
    If you disconnect the battery you will clear the error code and error memory!
    If you want to try to get warranty work done, you will need the error code. So do not disconnect the 12v battery.
    You can charge it while it is hooked up to the car.
  15. Scott M. Bleeker II
    Fairfield NJ
    So just try to charge it while still connected and drive it over to the shop to see if I can get it worked on? Will it actually go into ready mode with an HV battery error?
  16. Scott M. Bleeker II
    Fairfield NJ
    So after charging the 12v with the tender for about 17 hrs I tried to turn it on and it still wouldn't go into ready, showing 12.1~12.2v which was exactly the same as before. However, very recently I replaced the 12v and couldn't get it to go into ready with almost identical symptoms as this issue. I made my first post here (Prius won't go into ready mode after replacing 12v battery | PriusChat) and came to the conclusion that I didn't clean the corrosion off the battery terminals(which I didn't even try to do). After attempting a cleaning with a large steel wire brush that barely fit it got it to read 14v and ready the first time. However I probably wasn't completely thorough because of how big the brush was. As a result of the above listed methods failing, I have just purchased a dedicated battery terminal brush and went to town, which worked and allowed the car to ready and now reads 13.8v~14v.
    I'm glad I got it going again but I'm still concerned I haven't really solved the issue. The problem is that now I've learned that disconnecting the battery also resets the codes, I'm worried that I may have replaced my 12v in vein and there might still be a large repair waiting to leave me stranded somewhere. I'm hoping this isn't the case because I actually had to jump the 12v around the time I replaced the HV, so I assumed it was weak and waiting a month for the 12v to die didn't seem unreasonable at the time. But since I had to clear the codes to get it going, I'm thinking that there are only two possible things I can assume for now:
    1. I potentially just simply botched the 12v replacement and failed to clean the connections thoroughly enough and now I'm all set after giving them a more thorough scrubbing.
    2. Since I can't try to get some kind of warranty repair without active codes, the only thing I can do is wait for another dramatic triangle of death to pop up a week or two from now, as it did after my first attempt at the 12v replacement.
    Regardless, I think all I can really do is wait and hope for the best. Also, how likely is it that I cleaned just enough corrosion for it to start for two weeks, and then build up enough corrosion to break the good connection within that same time period(it has been consistently super humid for the past few weeks as well)? Any other thoughts?
  17. JC91006
    16,672
    8,518
    I believe you have an error that will only allow your car to start once and then it'll disable itself. That's why after you disconnect the 12v to reset, you'll be able to get it READY once.
  18. Scott M. Bleeker II
    Fairfield NJ
    That happened twice to me so far, once right before my 12v "died" the first time, and then again this time. It went into ready, yelled at me, and allowed me to drive around and get home until i turned it off and on again. However, like when I replaced the 12v the first time, all the errors went away and they stayed away for two weeks. This time the errors have seemed to completely disappear again, but if that wasn't the problem to begin with then it'll definitely crop up again. I wish I knew about the Dr. Prius app when I had my first bout of issues, would be helpful if I could find out whether I got the same error code twice.
  19. PriusCamper
    12,056
    4,893
    I went back to look at you first post to see if you mentioned what type of replacement 12v battery you used but there's not been any mentioned. Based on the battery voltage levels both new and after running on a trickle charge I suspect you must of bought a garbage YellowTop Optima 12v. Those people should be thrown in jail for the amount of defective 12v batteries they sell...
    But more important your P0AA6 error code points to how your hybrid transmisison relates to your hybrid battery pack. So getting a diagnosis for that code is the first step. But also getting a 12v battery that can hold a full 13volts of charge after sitting on a 13.8v trickle charger all day may slightly change the sub codes next time they show up, or if you're ridiculously lucky make them not show up again.
  20. Scott M. Bleeker II
    Fairfield NJ
    This is the battery I purchased off amazon:
    Should I order a better one and return this one? I think I still have a week left in amazon's return policy. If so, what battery would you recommend?
