Error code meaning,how to clear it.
Discussion in 'Prius v Technical Discussion' started by Saad Yousuf, Dec 31, 2020.
  1. Saad Yousuf
    Saad Yousuf Junior Member
    Sydney
    ----Australia----
    I went into diagnostic mode saw this error there is no check engine light.
    Where can I find all the explanation of codes.
    How do I clear it.
    What does it mean
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Welcome. I've never used diagnostic mode and I'm not sure what B1585 is, but that looks like it's remembering that it once had that code since it's in the "Memory" column, which is why you can't clear it with the "Code Clear" button. The column under "Current" is empty. Techstream will give you more info.
    Saad Yousuf likes this.
  3. Elektroingenieur
    2,515
    3,288
    Three Touring
    The diagnostic mode on the head unit is only for the audio and visual system and the navigation system; it’s not a general diagnostic or indicating system for the vehicle. As @jerrymildred kindly points out, to diagnose other systems on the car, you’d need to use a Toyota Techstream system or equivalent.
    See the Repair Manual (more info) for the version of the car that you have.
    Press and hold the Code CLR button for three seconds. You may also need to press and hold the Memory CLR button (on the previous System Check Mode screen) for three seconds.
    The Repair Manual says B1585 is “USB Media Malfunction,” and that it means an incompatible or malfunctioning USB device, or one with a corrupted or incompatible file system, has been connected to the car’s USB port.
    Saad Yousuf and jerrymildred like this.
  4. jerrymildred
    11,517
    14,171
    Tampa, FL
    Thanks. I had googled the code and that was the only plausible explanation I found, but I wasn't going to rent the Repair Manual to confirm it. I'm continually impressed the way you seem to always have the right info handy. (y)(y)
    Tim Jones and Elektroingenieur like this.
  5. ChapmanF
    19,045
    I'm kind of that way, during occasional two-day periods when my techinfo subscription is paid up....
  6. jerrymildred
    11,517
    14,171
    Tampa, FL
    You, also, are a veritable font of valuable information. And there are several others that keep me coming back to learn some more. Thanks guys!
    Tim Jones likes this.
  7. Mendel Leisk
    42,365
    Google.
  8. ChapmanF
    19,045
    With the important caveat that Google will find you all of:
    • what that code means in other cars that use the same code to mean something different
    • what that code means to people who don't know what that code means but are very sure of their guesses
    • spiffy videos giving very detailed explanations made up by people who don't know what the code means
    • also, occasionally, something accurate about what the code in your car is telling you.
    Looking codes up in the repair manual (more info) is a short-cut to that last category of information.
  9. jerrymildred
    11,517
    14,171
    Tampa, FL
    Yup! I've tried googling those codes. The answers are all over the place.
  10. Saad Yousuf
    Sydney
    ----Australia----
    I was able to clr it by pressing clr button for three seconds.
  11. Saad Yousuf
    Sydney
    ----Australia----
    Thank you everyone.
