Error code POA1D
Discussion in 'Gen 2 Prius Technical Discussion' started by Bob Cook, Feb 29, 2016.
  1. Bob Cook
    Bob Cook Junior Member
    Bob Cook
    Junior Member
    Start a Conversation
    I was driving my 2008 Prius and it abruptly slowed down and became undriveable. I had all of the warning lights - the red triangle master warning light, hybrid syatem warning light, and the check engine warning light. The car had to be towed home. The gas engine starts and runs - driving forward feels like the brakes are on - will not drive in reverse,. I checked the codes and had the following : POA1D, POA78, POA90, and P0A94. I've searched looking for solutions - any help is greatly appreciated. THANKS
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Where are you located? Tell us so that we can steer you to locally available (if any are local) resources .
    JeffD
  3. Bob Cook
    I am located in the Sacramento area - the battery is the original battery
  4. jdenenberg
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    One of the best independent Prius repair facilities is Luscious Garage in SF. I expect that you know that there are two batteries in your Gen2 Prius; the 12v and the HV (Traction) battery.
    JeffD
