1. farmhousenewbie
    farmhousenewbie New Member
    16
    Nashville, TN
    As stated, it was charged. Read the thread. The battery was removed and placed on a charger. Thanks for being so pompass, but next time read the whole thread before adding your two cents. Your advice or opinion is not needed if you cannot operate with all of the information.
    52,855
    any news?
  3. farmhousenewbie
    16
    Nashville, TN
    Battery, ecu, and actuator tested fine. "Itermittent issue" Toyota could not find any issue. Their advice was to drive until the light stays on.
    52,855
    brutal. what about the park motor? i wonder if theres a loose connection at one of the ecu's patrick wong mentioned.
  5. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    No worries, mate. I "operate" just fine. You even quoted what I said, but still failed to comprehend what I was saying. Somehow I don't think it is me that has a problem with reading and comprehension. You can lead a horse to water, but you can't make it drink.
    Message received and understood. Fine by me, have a nice life.
  6. farmhousenewbie
    16
    Nashville, TN
    It was not the battery. I replaced the shift control actuator and the problem is fixed.
  7. bisco
    52,855
    well done!(y)
    farmhousenewbie likes this.
  8. John McG.
    John McG. Junior Member
    55
    25
    A lot of older battery chargers will only charge an AGM battery to 12.6V. A newer AGM sensitive or selectable charger will get the voltage over 13V.
