Error codes p0300, p0310 AND p0302
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Coaks02, Sep 23, 2018.
  1. Coaks02
    Coaks02 New Member
    Northern CA
    Hey guys,
    I need a little help on this. Here is the background. 140k miles on the car, started running rough and kicked out a misfire code for Cylinder 1. I changed all four spark plugs and swapped the coils for 1 and 2. It started really rough when the gas engine would kick on, but it only lasts about 5 seconds. After running it a short while, I got the general misfire (P0300) and misfires for both cylinders 1 and 2 (P0301 and P0302). Before I start chasing this all over the place, I thought I would ask and see if anyone has some advice on this. Could it be possible that the coil originally on Cylinder 2 (now on one) also went bad in that short amount of time and now I need to replace 2 coils? Or could there be another issue that I'm not seeing? Thanks in advance for any help.
    52,558
    welcome!
    have you cleaned the egr circuit and intake manifold?
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,752
    1,780
    Bay Area
    Try swapping coils 3 and 4 with 1 and 2. Erase the codes and see if it’ll come back the same cylinders or not.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    It can sometimes be the fuel injector(s) as well.
    audiodave likes this.
  5. BZzap!
    BZzap! Senior Member
    1,607
    878
    As “bisco” asked, “Have you cleaned the EGR circuit and intake manifold?”. This is most likely the problem. This is really a common cause of engine startup rattle and rough running. Your discription fits the cause and effect to a tee.
  6. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Have you checked or replaced the spacrk plugs yet?
    Swapped the coils, and see what happens. If it does not fix it, get new ones and replace entirely. Are they expensive over your location?
    If that also does not fix, service the fuel injectors, and probably replace if that also does not solve it.
    Mehn, I just hope this is not related to cracked cylinder gasket on the concerned cylinders?
