Error codes
Discussion in 'Gen 2 Prius Technical Discussion' started by deafelf, Jun 1, 2023.
  1. deafelf
    deafelf Junior Member
    Mississippi
    I ran over some ruff road. The red triangle with an exclamation. The yellow ((!)) Light and the "VSC" Lit up. The cruise control quite. I had the codes checked at autozone, Advanced, and O'Reilly. P0a09 0200 0205 C1241 C1377 one time the codes and lights went out. Everything worked fine. Cruise control too. Then when I started it up the next time the lights came back on. The cruise control quite again. I'm baffled. I ordered front left and right speed sensors. Can anyone shed some light on this. My appreciated. Thanks for your feedback.
    52,878
    maybe a loose cable connector?
