Error message in japanese please help!!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Zornald, May 16, 2017.
  1. Zornald
    Zornald New Member
    Fiji
    While driving on the road I encountered the attached error in japanese. Please kindly seeking professional advise in advising what the error means and how could this be solved. Hopefully it's not anything serious as it scares me. Screenshot_2017-05-16-20-36-33.png
    imrantufail likes this.
  2. MPGesus
    MPGesus Junior Member
    17
    Midwest USA
    2022 Prius
    Here's what google says that means. Someone else will have to take it from here cause that's all I got.
    iPhone ?
  3. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    I think this is closer to what it said:
    ハイブリッドシステムチェック
    Google translates that to "Hybrid system check" (and the kana are basically sounding out the English words "hybrid system check" based on the pronunciation).
    Basically, there's a fault code stored, related to some part of the hybrid system (that includes the engine), you'll need to scan it, ideally with Techstream.
    imrantufail and MPGesus like this.
  4. imrantufail
    imrantufail New Member
    PAKISTAN
    HI EVERY ONE I GOT SAME ERROR MESSAGE TODAY ANY SOLUTION FOUND PLEASE LET ME KNOW
  5. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    It could be literally anything. You will need to use a scan tool like Techstream to check the fault code(s) that are stored.
    4md likes this.
  6. imrantufail
    PAKISTAN
    I STARTED MY PRIUS AFTER 3 HOURS AND NOW DRIVING MODE IS NOT CHANGING AND STILL HAVE YELLOW LIGHTS AND ERROR MESSAGE
    TOMORROW MORNING I WILL GO TO MECHANIC AND SEE WHAT HE TELLS
  7. imrantufail
    PAKISTAN
    my problem solved by simple resetting the system .hope it will work for you too
  8. Japanese Island
    Japanese Island New Member
    Fiji
    Hey Zornald,
    How did you fix the problem?
    Any other problem since you fixed it?
  9. UMER QURESHI
    UMER QURESHI New Member
    PAKISTAN
  10. Salamander_King
    Salamander_King Senior Member
    11,024
    8,973
    New England
    It's saying "An error occurred" . General error message without much detail. What was the car doing (or not doing) when this warning came on?
